Where can I buy these?
  • AKMac
    • Sep 2005
    • 141
    • Utah
    Hey guys, I'm getting ready to chrome these covers and I'm going to need to replace these seals. Does anyone know where I can purchase these? Thanks
    1979 XS1100 Special (Chrome Queen)
  • AKMac
    • Sep 2005
    • 141
    • Utah
    Also, I forgot, if anyone knows any useful tips for removing the oil sight glass, that would be much appreciated.
    • Yamaniac
      • Jul 2005
      • 262
      • Stilwell, KS
      bike bandit carries the kick starter oil seal
      7: OIL SEAL,SD-TYPE
      (USA) 358386-001 $6.82
      It doesn't look like the other two seals were broken out on the microfiche. ???
      Yamaniac
      '79 xs11 sf - WidowMaker, 750 final drive
      '80 xs1100 sg- ENEMY#1 parts bike no title(free)
      '79 f- frame and swingarm (and title)
      '82 yz 490- needs a cylinder, head, & new piston, etc. Got one for sale?
      '88 Honda cbr600- Running, finally! Training bike for swmbo, maybe a stunt bike for me eventually.
        Not good to use old Rubbers!
        Hey AkMac,
        Here are your parts per Yamaha parts fiche, and then right below each is the BikeBandit part# and price.
        Don't have any hint for the site glass, but it's ALSO available!!
        93104-14059-00 OIL SEAL (S0-14-25-5-HS) CLUTCH THROWOUT SEAL
        25: OIL SEAL,SO-TYPE (U49) 358755-001 $4.24
        93102-12106-00 OIL SEAL (SD-12-22-5) Shift Shaft Seal
        7: OIL SEAL,SD-TYPE (SD 12-22-5 HS) 4983-001 $4.47
        93102-20108-00 OIL SEAL (SD-20-30-7) Kick Start Seal
        7: OIL SEAL,SD-TYPE (USA) 358386-001 $6.82
        2H7-15361-00-00 GAUGE, LEVEL Site Glass Window
        20: GAUGE,LEVEL 22632-001 $15.24
          How to find parts.
          Hey Theron,
          Nice try!!! You have to go to the actual section for the needed parts, not just the CrankCase Covers!!
          Go to the Shift Shaft Pedal, The KickStarter, The Clutch, and that's how I found the parts! Keep at it!
          • dewibp
            • Jun 2005
            • 315
            • Work out of Dakota Dunes SD but live in eastern Iowa (Quad Cities)
            I just finished chroming my side covers and had to remove the "eye ball" too. I just used about a 1 1/2 x 1 1/2 inch board and used a belt sander to "custom" fit the end to match up with the "eye ball". It pressed out very easily and back in with the same board. Also use a little lubricant on the "eye ball" when you reinstall it.
            DEW
            One Red "Creation 1"
            One Black"Creation 2"
            One Black"Creation 3"
            One ???? "Creation 4"
            One ???? "Creation 5"
            One ???? "Parts Bike"
            All the above 1100 Specials
            78 Standard (Ruf Ruf)
            1980 Midnight Special
            1978 650 SE
            • AKMac
              • Sep 2005
              • 141
              • Utah
              Re: How to find parts.
              Hey Theron,
              Now I see. I just went to crank case covers and didn't see them.
              Well, here's how she sits...I have a lot of work ahead of me.
              • dewibp
                • Jun 2005
                • 315
                Looks like a pretty clean ole bike! Some times "you can only put so much lip stick on a pig" but yours looks pretty good to start with.
                DEW
                1978 650 SE
                • dewibp
                  • Jun 2005
                  • 315
                  So how much stuff are you getting chromed? I went with the valve cover, outside carb lids and bowls, choke assembly, all four side covers and the starter covers. I would also suggest you spend about $20 for a set of SS allen headed screws to use when you put it back together. They are listed on ebay. If you need the name of the guy I have a link to get to him. They NEVER rust. Oh, don't forget to use a little never sieze on the SS screws to keep them from seizing in the aluminum.
                  DEW
                  1978 650 SE
                  • AKMac
                    • Sep 2005
                    • 141
                    • Utah
                    I'm doing all for side covers, valve cover, footpeg brackets, wheels, carb diaphragm covers, and float bowls. I would like to do the starter cover, and the cover next to it (the one with the bearing), but I couldn't get the starter cover off for the life of me. I was also afraid of a screwing up the bearings on the cover next to it so I think I'll just leave them alone. I have a spare final drive that I would like to have chromed, but I have no way of pressing out the bearings.
                    I've already got the SS bolt kits, so I'm good to go.
                    I'm sort of new to all of this, so not only am I trying to make this into a cool bike, but it's also a learning experience.
                    • Yamaniac
                      • Jul 2005
                      • 262
                      • Stilwell, KS
                      miserably trying
                      Hey T.C.
                      Yeah, I think I should leave the part finding to you, as you are most excellent at it. Didn't look too hard though, had drywall sanding and painting to do tonight, so I was in a little bit of a hurry...but no excuse for not finding the right info.
                      AKMac and dewibp:
                      For the parts you are having chromed, would you mind telling me ballpark wise of the cost? I looked up some shops in my area, but haven't priced anything yet. I guess I'd also want to add both fenders since both are scratched up and pitted from rust.
                      Thanks
                      Theron
                      Yamaniac
                      • DeanR
                        • Jan 2005
                        • 1493
                        • Finger Lakes NY
                        I'm also wondering about costs of re chroming. Only place around here I've found costs a fortune he calls it 'show quality chrome'.
                        80 SG
                        81 SH in parts
                        99 ST1100
                        91 ST1100
                        • AKMac
                          • Sep 2005
                          • 141
                          • Utah
                          I was quoted by a place in Grand Junction Colorado, $250 for each wheel, and $75 for each side cover. I'll let you guys know what it actually ends up costing. Supposedly these guys are very good, and so far they've been great over the phone.
                          • dewibp
                            • Jun 2005
                            • 315
                            I've got about $500 in all my chrome work. I had a place in Omaha, Neb. do it by the name of Industrial Plating. I didn't go with the show quality chrome finish as your paying a premium for the extra buffing that, after looking at the chromed parts, would not be worth it to me.
                            DEW
                            1978 650 SE
                            • AKMac
                              • Sep 2005
                              • 141
                              • Utah
                              Hey dewibp, on your clutch housing, did you remove the piece on that back side that has three circular grooves, I think it's called the "push screw housing"? If so, how did you do it without messing it up?
                              I'm almost ready for chrome. I removed the oil window, I got the front and rear wheel entirely apart, and took the triple tree and speedo bracket off today. I decided they would look good in chrome
