Please set me straight
  • SanDiegoMike
    • 192
    • Near the beach!
    Alright...I need to know...is it better to run conventional oil or synthetics in your crankcase. Are the synthetics too "thin" to keep the bike running smoothly even though the oil change interval is supposedly longer? I just want what is best for my 25 year old engine. I value your opinions, and I have read through the tech tips as far as the technical aspects of oil. I want to know what YOU guys are running...
    Thanks-
    SDMike
    Hi...my name is Mike, and I'm a lane-splitter.
    '80 XS1100SG (mine)
    '87 CMX450C Rebel (daughter's first bike)
  • 81xsproject
    • 3185
    • Fortuna, CA
    From what I've read here, you can't beat the Valvoline MC oil.
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
    • Parr8hed
      • Aug 2003
      • 444
      • Southern Indiana
      please ask this question 20 more times and you will get that many different answers. Some people on this site swear by it, and some say that it is the devil. I use castrol 20w50. That is me. Do a search and you will be up all night reading about what everyone thinks about the different kind of oils. If you get bored with that search then do one on tires!!!! Lots of different opinions here.
      Travis Miller
      1978 E
        What one person swears by.... the other person swears AT. The heavy duty diesel oils are supposed to do well... and they are cheap. Try something... if your clutches slip with it, pull the plug and try another. Just don't use anything that has the words "Energy Conserving" in the little circle stamp on the oil bottle. The bottom of the circle should be blank preferably.
        • xs650mike
          • 1286
          • Lake County, California
          Been running Shell Rotella T 15w40 diesel tractor oil. Formulated for wet clutches. $8/gal. at K-mart and Walmart. When the weather turns hot (gets 105° F a lot around here in summer) I will probably switch to 20w50 Castrol GTX or Valvolene. I've used 15w50 Mobil 1 synthetic auto oil in the past, no problems with that. I don't suppose it really matters much, just so it's the right weight and you change it often. I generally change it at 2,000 miles. 1,500 miles on the XS650s but they don't have oil filters, just screens. Yamaha recommends 20w40, but the only 20w40 you can get is Yamalube, LOL.
          Shiny side up,
          650 Mike
          XS1100SF "Rusty", runs great, 96k miles
          XS650SJ "The Black Bike", engine from XS650H with 750cc big bore kit, 30k miles
          Life is not a journey to the grave with the intention of arriving safely in one pretty and well preserved piece, but to skid in broadside, thoroughly used up, worn out and defiantly shouting, "WOW, what a ride !" - [URL="http://www.flyingsnail.com/Sprung/index.html"]Sprung[/URL]
          • Geezer
            • May 2003
            • 2985
            • Willamina, Oregon 97229
            Or Castrol. Also don't get suckered by advertizing on special motorcycle oils. Also the last I checked (along time ago) both Yamalube and Hondaline oil were both made by Ashland oil (the maker of Valvoline.)
            Geezer
            • edgo
              • Jul 2005
              • 138
              • Tampa FL
              I just changed to Valvoline Four Stroke and I notice a big difference over Rotella. The engine is not as noisy and it shifts much smoother.
              Next.......
              Ed
              79 XS1100SF
              78 YZ400E
              81 SR500
              79 RM250
              77 YZ400D
              05 RM250
              78 CR 250 Husky w/TT500 motor
              • xs650mike
                • 1286
                Motorcycle Oil or Auto Oil? Cutting through the hype.
                This article's been around awhile but in case you missed it here's what Motorcycle Consumer News has to say on the subject:
                Shiny side up,
                650 Mike
                • GNEPIG
                  • Apr 2005
                  • 1647
                  • fl
                  .. im throwin in with the valvoline 20/50 MC oil crowd. it does every thing for my bike that Edgo says it does for his plus my clutches dont slip.
                  i get it at the auto store for $3.20 a qt
                  .. i agree with that other guy from washington "symthetics are pure evil"
                  • webbcraft2150
                    • Sep 2002
                    • 1605
                    • AUSTIN.TX
                    Run synthetics or not, seems to be a hot topic. I have stuck with Castrol in the many bikes I have owned and run it in my cars, truck and boat. I do run syn gear lube in the bike and the truck (31 year old Dodge Power Wagon). Has easily cleared over 200k in the car and over 300k in the truck. It is interesting to note that during my tenure as mechanic and service manager for a couple of boat dealers, Mercury Marine does not condone the use of syn oil in its sterndrive/inboard engines yet there high performance engines come from the factory with Mobil 1. Go figure. Idmar marine does condone the use of syn oil, basically the same engine as Merc. Mercury also did not like muti-vis oils for there engines till they came out with there own branded multi-vis oil at $6 to 7$ per quart. Have always run 40wt GTX in my boat motors with no failures. My last boat was sold with over 500 hard hours on the 305, never had to add oil. Current boat is pushing 300 hours and still runs as strong as the day I bought it. With 63k trouble free miles on the XS, not gonna change now.
