Some of you may have seen the aux tank I rigged up for the ride to Reno using a ABS marine grade fuel tank for an outboard motor. I strapped it to my luggage rack and it gave me an extra 3.5 gallons. It rocked for the added distance. The thing I didn't like is it ate my rack space.
Well I was so pleased with the system I decided to build a tank that would allow me to still use my rack to place bag on. I welded up an aluminum tank that will sit on my luggage rack just like the outboard rig. But this one will allow me to sit a bag on top of the tank. This aluminum tank holds 2.8 gallons and should give me an extra 90 to 100 miles of range beyond the normal 150 or so of the Maxim. Here a few pics if you're interested. It has an 1.5" inlet and a 1/4" outlet/drain.
The filler is the rear of the tank
left side
right side
vented cap
left side
right side
vented cap
Hell, my ugly ass on it is enough of a distraction... At least with the tank mounted to the rear, the eye is not drawn to it, and it won't distract from the look of the bike in general, and should there ever be a spill/ leak, it would not be as dangerous as it would be if it was mounted on top of the fuel tank.
