Jetting and Carbs
  • BJGLIDE
    • Apr 2005
    • 15
    I am also trying to re-jet my carbs. I do not have the stock carbs. I am running 38mm flat slide mikunis. Fuel fouling plugs like crazy. Replacing 136.5 jets with 125s. I know some have ran flat slides on their bikes what jet size did you use?
    Thanks for the help
    elmo check your email
    • GNEPIG
      • Apr 2005
      • 1657
      • fl
      .. these look like the cross over carb set we are talking about
      or are they for a suzuki, i've seem this same set on a suzuki before also.. hmm, 4 holes in the ventury, cast aluminum diaphram caps ....
      .. someone buy them and lets disect them
        Those carbs on ebay are for an 80 XS1100. Definitly not a 79. The 81 carbs would have a drain nipple on the bottom of the bowl. The seller doesn't have them described properly. He says they'll fit on a 750? The 750 is a triple. You would have to remove one carb and then there is the spacing between the carbs issue, and, and, and...
