Fog/Driving/Aux Lights...
  • Street_Rat78
    • Sep 2005
    • 253
    • Columbia, SC
    I was looking at my floorboards and crash bars last night and got to thinking about adding a small pair of fog/driving lights to them. What do you folk's think about that. Nothing fancy, just a little set of maybe 3" ovals on the top of crash bars to give me that extra bit of visability.
    I know it's been said that the worst vice is advice, but I want some opinions from the more seasoned guys on any pro's or con's that may come from my doing this.
    ~ Street Rat ~
    Mitch
    '78 XS1100 "My Mistress"
    Knowledge is Experience. Everything else is just Information
  • Street_Rat78
    • Sep 2005
    • 253
    • Columbia, SC
    I know I posted this in the Members Lounge as a reply to another thread bit I really haven't had any feedback, so I thought I would stick it here ((where it belongs)) by it self to see if anyone had any ideas or advice for an up and rising newbie ... the idea has merit ((as an idea)) but I just don't know all the finite details well enough to know whether or not this will work ... you be the judge.
    ~ Street Rat ~
    Mitch
    • scalded dog
      • 458
      I am running side marker lights on my fully dressed 79 standard, they havn't caused any problems, but on another xs 1100 fully dressed I ran them and, some fog lights, and the system couldn't handle it. I havn't tried on this one yet. Later 'Dog
      • Pat Kelly
        • 3046
        • Golden Valley, AZ
        I have a set of 55watt halogen fog lights on my E. I have to use them quite sparingly and not while idling. They draw more than my alternator puts out (I have a voltmeter on my fairing. If I leave them on during my 8 minute ride to work (going the shortest route) the bike is sputtering before I get there. I turn the foglights off and things get back to normal.
        It gets very foggy here. Visability can get down to less than 50 feet.
        Pat Kelly
        <p-lkelly@sbcglobal.net>
        1978 XS1100E (The Force)
        1980 XS1100LG (The Dark Side)
        1999 Suburban (The Ship)
        1994 Dodge Spirit (Son #1)
        1968 F100 (Valentine)
        • strom
          • 1577
          • Slovenia, EU
          I'm thinking along the same lines here... about adding extra lights in front. A friend got some nice 12V bulbs that are bright as hell, but about 25W or something like that. Brighter than my headlamp, I **** you not. I know there was a thread or a tech tip about how much extra power the alternator puts out... but cant find it at the moment. Would be nice to know so I don't put too much power guzzlers on.
          LP
          • Street_Rat78
            • Sep 2005
            • 253
            • Columbia, SC
            I'm sure if there's an thread on here about extra juice put out, and whether or not aux lights would run off of it, one of the Moderators or Gu-Ru's would know where to find it.
            ~ Street Rat ~
            Mitch
            • strom
              • 1577
              • Slovenia, EU
              Don't kill me... I'm just quoting Sixtysix... who is apparently absent at the moment.
              OK, heres what I found... BTW, where IS our beloved 66?! Don't remember him posting recently. Hope he is OK.
              OK, without further to do and getting infected by germans... here is the post... I mean... isnt it oblivious? (yeah yeah, too much Cow & Chicken)
              Sorry but the XS has about 8 amps of capacity available after the normal stuff, and that is only at higher RPMS (above 2500). Switching your driving lights through a relay does not 'add' any power, it only allows the switch to pick up the relay instead of powering the lights directly, it also allows you to switch it with the ignition power or another source of your choice.
              I tried to put on 55W driving lights and found that they drew too much power. Here is a post that I pieced together on the other list when somebody asked about power output on an XS:
              Depends on who you listen to....
              Greg LaPook posted this a while back:
              I have measured the output of the alternator with a new voltage regulator installed. The results are:
              1000rpm = 5.6 amps
              1500 = 11.7
              2000 = 17.8
              2500 = 20.4
              3000 = 22.2
              4000 = 23.9
              5000 = 24.8
              6000 = 28.8
              My bike is a 1980G standard and the specifications state that the alternator should put out 20 amps which is obviously a conservative rating.
              Multiple the current by 12 to get wattage figures. Remember you have a 55/60 watt head light, several 15 - 25 watt tail/turn lights, brake light, resistance in connectors, and base line power needed to run the ignition system. At low RPMs you are likely not putting out enough electrical power to overcome the drain of the accessory lights. (A pair of 55 watt riding lights takes up almost 10 amps of power.)
              Later Yamaha bikes went to a brush-type alternator design. (My 82 XJ and '83 XS 400 both have this type.) This design has a higher output, 80 to 100 watts more on the XJ over the XS if I remember correctly. (It is one of the reasons the XJ engine has different cases on the engine's right side.)
              Result is that accessory lights should probably be turned off if you are spending much time below 3000 RPM, such as idling at stop lights or commuting around town. No way of increasing the output that I know of. You could try running heavier gauge wire to the accessories to cut down on line resistance and switch the lights through a relay, cutting out the switch resistance.
              Jerry Feilds
              A formula I learned was take the number of Watts you are running, divide them by 12volts, and that gets you the amps you are drawing. Now, they have stated that the XS produces 20 amps, well, you first have your main headlight stock at 55watts, then 2 tail lights 8watts each,license plate 4watts x 2; so far 79watts ~6.5amps draw...not to mention how many amps to run the engine system..lets say 3 amps gestimate for total of 9-10 amps.....now add 2 more halogen driving lights at 55watts each, 110w/12v =~9 more amps, plus the extra drain when you hit the brake lights at another 55watts/4amps, and turn signals/pair also at 55watts/4amps, plus turn signal indicator at 3.4watts,neutral light indicator at 3.4 watts,gauges lights at 3.4 watts x 4=13.6 watts:total extra is total ~10 amps ......so you can see how much stress you're putting on the electrical system!!
              I found a pair of Non-Halogen driving lights...only 35watts per bulb, that I mounted on mine, and I don't use them very often, rarely drive at night, and only turn them on in the day when I want to be seen for special traffic situations.
              Safe driving....T.C. 81SH Godzilla
              Numbers from the microfiche for a '79 XS:
              A.C. generator output is 14.5 volts at 20 amps max measured at 5,000 RPM. 290 watts available, theoretically.
              For the '82 XJ:
              A.C. generator output is 14 volts at 26 amps max measured at 5,000 RPM. 364 watts to work with.
              If you are running a 60 watt headlight, 3 running lights at 25 watts each, stop light at another 25 watts, you are up to 160 watts without accounting for power needed for ignition system and optional relays. Call the total 200 watts with turn signals working. Doesn't give you a lot to work with, 90 watts, and if you are running 2 each 55 watt aux lights, you are pushing the limit and probably discharging the battery at low speeds.
              FWIW, many people have reported that the actual output is higher than the book figures. However, old and corroded connectors can eat up some of the power due to resistance, so the 290 watt figure is probably a good ballpark number. If you do go with the optional lights, use them at highway speeds only to avoid discharging the battery.
              FWIW2: The XJ uses a different charging system; it has brushes where the XS version does not. That is one of the reasons the right engine cover on the XJ looks different than the XS, and why some accessories, such as engine guards, are not a bolt-on swap between the XS and XJ.
              Jerry Fields
              And finally from me:
              Yesterday I went on a ride with about a hundred harleys and maybe 20 or so bikes of other manufacturer. It was a poker run and bike blessing run. At the second stop my bike would not start, it acted as if the battery was dead. I was pissed that I had to push start my Yamaha in front of all those Harleys (I think only 2 saw me). I have a new maint. free battery and I managed to finsh the run by shutting off my aux. lights and only driving in 4th to keep the revs up. It started OK the next three stops.
              When i got home I put the battery charger on and the battery was very low (was drawing 15 Amps , then I put it on 2 amp charge). The battery charged up great overnight. In the morning I checked the battery voltage (12.8) and started the bike. Voltage remained at 12.5 -12.8 and went up to a max of 14.5 at about 4000 RPM. This seems pretty normal to me. Then I turned on my aux lights.....I could not get above 12.8 even at 4000RPM. There was no wattage listed on the package for the bulbs so I assumed they were low. I checked them and they were drawing a max of 8.25 amps at 4000RPM, with the voltage at 12.8 across the battery. This works out to about 52 W per bulb. I put these lights on last fall and did not notice any problem until yesterday. I left them on once or twice and hooked up a relay to drive them, so they would not come on until the key was on, I also put in a switch to shut them off by cutting the ground to the relay, (all of this the day before yesterday).
              Now how much extra juice does an XS have (mine is an 80G) ? I am not running any other aux equipment. I thought somebody said it was like 20 Amps. What wattage bulbs can I run and not effect the charging circuit? Do I have some other problem, like weak stator (or is that even possible)? Or something else gone bad? Did my relay mod cause some problem that I am not thinking of?<<
              Then after several replies, which had a variety of answers...........
              >>Thanks to all who replied to my charging problem. Here is the update. Today I replaced the regulator/rectifier unit and the problem was still exactly the same. So I replaced the stator and coil unit, and the problem was still the same. The resistance readings were OK, but I figured I'd give it a try. I cleaned all connections and did not find any corroded ones. So here is my take on the problem: Two extra 50W lights are just too much for an XS to handle.
              I set my throttle lock at 2000 RPM like the book said and after a few seconds the voltage did build up to 14.25V, book says 14.5 +/- .3V, (does get to 14.5 before 3000RPM) so I guess it is within spec. Bike acted exactly the same with both stator/field coil units and both regulator/rectifier units. With the (aux) lights on I could not get more than 12.8 volt across the battery.
              So what I have done, is found a set of 35W lights and mounted them in place of the 55W ones. I have yet to do a check out of the system with them on.
              Gary Granger
              __________________
              LP
                Nice to be quoted!
                Hey Strom,
                Thanks for digging that up, saved me alot of typing! Followup to what I had said back then. I decided that since the XS11's charging system is so weak, but I wanted to be able to run AUX lights, that is what drove me to the LED conversion, both for the running/brake lights as well as the turn signals!
                Years ago, I burned out a REG/RECT by running 2 pairs of extra aux tail/brake lights....was more worried about being rear ended for some reason!? My Special has the dual tail light fixture, and I also added an extra fixture on my back rest for the high brake light affect! SO...when you add four tail lights, 8 watts each, and then hit the brakes, thats' 27watts x 4, plus at 55watts for turn signals, and it's a considerable load on the system, and usually when the engine is at or close to idle!!! That's a total of 163 watts, over 13.5 AMPS
                Now, convert to LED's, each brake assembly only draws 0.3 amps each, turn signals also only 0.3 amps each, so when stopping and turn signals on, I'm only drawing 1.2 AMPs, lots of spare wattage to run my pair of 55watt halogen driving lights along with my 55/60watt head light!
                So...I highly recommend the LED conversion if you want some more headlight power!!
                • Yamaniac
                  • Jul 2005
                  • 262
                  • Stilwell, KS
                  I had the same thought about LED's and adding additional forward lighting...Hadn't done the math to see if would work though, and thanks to you, now I shouldn't have to.
                  Can you tell us where you purchased your LEDs, and explain whether they are splice and go, or if you had to do any modifications to current wiring for the LEDs to work.
                  Thanks
                  Theron
                  Yamaniac
                  '79 xs11 sf - WidowMaker, 750 final drive
                  '80 xs1100 sg- ENEMY#1 parts bike no title(free)
                  '79 f- frame and swingarm (and title)
                  '82 yz 490- needs a cylinder, head, & new piston, etc. Got one for sale?
                  '88 Honda cbr600- Running, finally! Training bike for swmbo, maybe a stunt bike for me eventually.
                  • rglanvil
                    • Feb 2006
                    • 6
                    • Friendswood, Texas
                    Sylvania Xenarc HID Driving Lights
                    I have had trouble with my XS1100E's charging system keeping up with a pair of regular 55W quartz iodide driving lights. I was disappointed with their light output too.
                    I considered Light Emitting Diode driving lights but then investigated the Sylvania Xenarc X1010 high intensity discharge driving lights.
                    I recently purchased a set on Ebay for $250 and installed them. Wow what a difference!
                    The lights/ballasts only draw 35 watts each and oh what a difference they've made to my night driving experience. They put out a constant light intensity regardless of swings in the battery voltage due to engine RPM. They emit a white/blue light compared to the yellow emmited by by Sylvania Silver Star H1 & H3 bulbs.
                    My charging system is still having problems. I suspect one of the connectors has built up some corrosion over the years because I can only get my charged battery voltage up to 13 volts at 2000 RPM. Once I get the alternator back to producing a 14.5 +/- 0.3 Volts @ 2000 RPM, my H1 & H3 Sylvania Silver Star bulbs should really compliment the Sylvania Xenarc X1010 HID driving lights.
                    • prometheus578
                      XS-XJ Super Guru (RESIGNED)
                      • Aug 2004
                      • 4012
                      • Olympia , Wa.
                      &quot;A bright idea&quot;
                      That should answer most of your questions.
                        You can L.E.D. a Horse to Water?
                        Hey Theron,
                        Check out these links that are in the tech tips, Mods, Electrical:
                        Turn Signal LED Mod
                        Brake L.E.D. Mod
                        I did cut out a section of the tail light lens, but now probably feel that it may not have been necessary. I liked using the larger array vs. the smaller bulbs, plus the bulb sockets don't point directly rearward, and even with wide angle LEDs, they still don't seem as visible from an angle. And I wanted a WIDER bulb pattern, possibly more visible especially in the day time!?
                        So...you can use the premade round socket bulbs to preserve your OEM configuration, or you can cut and splice, and save some $$, but spend more time, effort. Your choice!
                        • Yamaniac
                          • Jul 2005
                          • 262
                          • Stilwell, KS
                          ok, I admit, I can't read
                          Prometheus and TopCat,
                          Thanks for the useful thread links.
                          It has become apparent that I need to Read Through The F'n Website about 10 times before asking any more questions. Seems that just about everything has been covered, and and pretty great detail as well.
                          appreciate it.
                          Theron
                          Yamaniac
                          • mro
                            • 4276
                            • Hayward, California
                            Electrical Mod
                            Does anyone know the spec's on Geezer's reg/rec unit.
                            From what I've read it will help at lower RPM's, but don't know amp out put spec.
                            mro
                              Geezer's Reg/Rect Specs.
                              Hey Mike,
                              Geezer's Reg/Rect doesn't provide for more charging amps, it just gets the charging rate up faster at lower rpms, made with heavy duty or more robust components, hence his lifetime guarantee!
                              You would need to put an XJ's brushed alternator unit on to get more amps!
