Scott brought his '78E over from Calgary this weekend so we could check out a few things, do a tune-up, etc, etc.
At one point while we had the sidecovers both off and I hit the starter button, Scott noticed some serious arcing happening where the battery ground cable attached to the frame. I shut it down then started it again so I could see and sure enough, it was arcing from the screw head across to the frame!
When checked, the screw was tight. However, when we removed it, the threads were pretty badly corroded. I also noticed the head of the screw was quite warm, perhaps from the resistance to the major current while starting. We cleaned up the screw, the washer, and the mounting hole, put it all together and the arcing went away.
I've never seen this before, and it is not something you would tend to see unless you were looking for it. I'll have to make a point of watching for this on the rest of the fleet.
