Need a tach?
  • MAXIMAN
    • Jan 2005
    • 1817
    Need a tach?
    I have a tach off a Special but the needle wobbles. If anyone can use it or fix it lemme know and it's yours. First come first serve.
    rocktone@aol.com
  • 81xsproject
    • 3185
    • Fortuna, CA
    I just got done opening mine up and attempting to fix it. If it no longer works as a result of my handywork, I'll be letting you know.
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
    • 81xsproject
      • 3185
      • Fortuna, CA
      Did a new tach fix the problem?
      '81 XS1100 SH
      Sep. 12th 2015
      RIP
      • Bohn Frazer
        • Jul 2003
        • 45
        • Shawnee, KS
        XS 1100 Tachometer
        Mine (XS1100SG)started fluctuating shortly after I bought it a couple of years ago. I bought two used tachs which looked good but had the same problem. I thought the problem might be in the wiring to the tach but could find no problem. I finally found a new tach, installed it, and now it works perfectly. I suspect there is an inherent flaw which causes these tachometers to start working erratically. . . Bohn F.
        Bohn
        78 XS750SE Bought New In 78
        80 XS1100SG "XS Combination"
        • bandet01
          • 698
          • connersville indiana
          well i heard there is a fix for them tacks that have the wobble it is a little ball bearing in the tack somewhere i havent had mine apart yet to find it and it needs oiled and the wobble will go away
          79 yamaha xs1100f standard
          best 1/4 mile 13.282@99.40
          • MAXIMAN
            • Jan 2005
            • 1817
            Yes.
