Do you use anti-seize compound?
  • Mike Hart
    • 1025
    • Seattle, Washington
    like on spark plugs, carb screws, etc? I do.
    If yes, tell us what you use it on.
    42
    Yes
    71.43%
    30
    No
    19.05%
    8
    Never heard of it
    9.52%
    4
  • xssiveone
    • 766
    • Windsor,Ontario,Canada
    Re: Do you use anti-seize compound?
    Yes, on exhaust nuts, wheel studs (car) and ANYTHING I come across that is exposed to moisture that I might someday want to take apart again.
    Brian
    remembering the same thing!
      yes, on pretty much everything I take apart before I put it back together...
      • Dragonrider
        • 1219
        • Garland, Texas
        Use it anytime that you have steel into aluminum. Makes your life, or maybe the next owner's life much easier.
        CUAgain,
        Daniel Meyer
        • xjguy
          • Aug 2002
          • 93
          • georgia
          antiseize
          on one side of my valve cover gaskets, back of brake pads, caliper pins
          • Bill__Woods
            • 281
            • Circleville, Ohio
            Hello,
            i use it on some fasteners, but never on spark plugs. Spark plug makers go to great lengths to make plugs that will not corrode into the head. I have fixed cars where people have used too much anti-sieze and caused the cylinder to misfire. I use a lot more locktite than anti-sieze.
            Tip: Fill and old Frenchs mustaed jar with antisieze. this works much,much better than the brush. Less of a mess
            Bill Woods
            1981 Yamaha XS1100SH (Eleven Special)
            1985 Kawasuki GS425 Mojave ATV
            2006 Yamaha Wolverine 450 4x4 ATV
            • Dragonrider
              • 1219
              • Garland, Texas
              After starting a simple tune-up on my wife's '68 Mercedes 250S (gangster car), and ending up doing a head job because a spark-plug broke off in the head and could not be removed with anything short of a machine shop, I use antiseize on spark-plugs too . . . if they are into an aluminum head at least.
              What should have been a 20 minute job turned into a two week ordeal, and that included about 20 hours of wrench time.
              CUAgain,
              Daniel Meyer
              • Jean Luc
                • 23
                • Detroit, MI
                I use Copper Anti-Sieze on any steel bolt touching aluminum. It makes life a WHOLE lot easier the next time the assembly need to come apart.
                Ciao,
                JL
                82 XJ1100 (Not Named Yet)
                Life not only begins at forty, it also begins to show.
                  • 5058
                  I like the applicator tip. I use the stuff on spark plug threads. Steel + aluminum + heat + time = stripped-out plug hole. I had to helicoil one. Sid Clark did too.
                  Originally posted by Bill__Woods
                  Hello,
                  • xssiveone
                    • 766
                    What is the main difference between types of anti-sieze compounds? Dad used copper because that was what he used at work. In the repair shop at MY work, what they use looks to be aluminum as it is almost silver in colour. Anyone know what advantages/disadvantages of the different types?
                    Brian
                      I use Loctite 767 which looks very 'silvery' , no copper colour at all. The label on the container says it contains copper and silica quartz.
                      • xssiveone
                        • 766
                        Just did something REALLY radical and "looked at the container"!! Sorta feels like (R)ead (T)he (FRIENDLY) (M)anual... It's a nickel/graphite composition that is used in areas where exposure to high (2400F) and acids are likely to be encountered.
                        Brian
                        • kenkrieger
                          • 123
                          • Transplanted to Virginia
                          I use anti seize anytime I have disimmilar metals together,and where high heat and corrosion are a factor,,,over much of the Motorcycle this is the case. So everytime I take something apart it gets a little treatment. Except in the carb area, not necessary in my experiance. YMMV
                          Ken Krieger
                          Chesterfield, Va.
                          81 XS1100SH - Radar Rider
                          82 XJ1100J - Black and Blue
                          82 XJ1100J - Bucket o Bolts
                          79 XS1100SF - Road Raider
                          1980 XS1100 - Frankenbike
                          85 XJ700 Maxim
                          06 VMax - Black Max
                          85 650 Nighthawk
                          • buffalo
                            • Aug 2002
                            • 141
                            • Carson City, NV.
                            I have worked the last 20 years as a mechanic and use it anytime I have dissimilar metals joining (ie. steel screw into aluminum) and also anywhere moisture and corrosion can be a problem (almost anywhere on a motorcycle). Living in the "snow belt" I can't guess how many hours I have wasted freeing corroded nuts and bolts.
                            I find the silver colored Loctite brand to be the best, but if you have the copper use it, it is much better than nothing. In a pinch toothpaste also works surprisingly well (not gel type).
                            I do not recommend using it in critical places where lock nuts are required such as axle nuts and motor mounts.
                            buffalo
                            80 XS1100SG
                            • rockyr74
                              • 75
                              • Indiana
                              I have a can of "nuclear grade" nickel never seize that went home in my lunch pail about 25 years ago. I put a slight dab on spark plugs and not much else.
                              Rocky
                              00 Cagiva Gran Canyon
                              80 XS11 Special -sold
                              77 HD Sportster
                              75 Norton Commando
