Top speed with chaindrive.
  • mro
    • 4276
    • Hayward, California
    Moto, John says motorbikes down here run backwards
    Probably meant that when you guys flush (you do flush?) it spins backwards from our point of view and the Jap engineers just thought that they would make there bike spin backwards too, so it would appeal to you.
    mro
    • pggg
      • 1609
      • NZ
      GNE, been scrounging around local trader sites for a cheap nitrous unit or components. Not a hell of a lot going at the moment. Still need to study up and get more clued up on the processes involved yet though. I can get hoses and compressed air components from a local dealer, but need to compare costs for single parts compared to a whole package. Quite possible to spend more bucks on a DIY job than on a new unit! Still keen on the idea though.
      • pggg
        • 1609
        • NZ
        MRO, just checked, water went down the sink CLOCKWISE. Now, this has always been a mystery, what's it do up there? BTW, our low pressure weather systems spin clockwise. High pressure anticlockwise. Does this mean your cyclones are in fact anticyclones? Do your seagulls fly upsidedown?
        • chevy45412001
          • Mar 2003
          • 1412
          • Jacksonville Florida
          #34
          pgg
          hey mate, switches only need to be those tiny micro switches, on when the button is pushed in and off when released. rig up a mount so when you hit full throttle the tang on your carb hits the button. A seperate fuel line is not manditory but well worth the effort to install.plumbed into the nitrus circuit.as stated above if for ANY reason your fuel falls short chances are very good you'll be looking for a different motor. you may have good reactions but the NOS is quicker.....trust me.and actually if you shop around you can get a nos kit roughly 300-500 american. That will give you all the parts and bits you need to stay laffin..
          1982 XJ 1100
          • bandet01
            • 698
            • connersville indiana
            #35
            i was looking into a ready to run kit for the 4 cyl bikes and it runs right around 700 after you get the pump and everything you need and everything needed to run the kit safe
            79 yamaha xs1100f standard
            best 1/4 mile 13.282@99.40
            • mro
              • 4276
              #36
              My thought
              make 2 manifolds, 1 for fuel, 1 for no2
              (1 port for each carb and gas, 8 total)
              need to know volume of gases needed
              jet manifolds accordingly
              (manifolds could be made small enough to fit inside a stock air box)
              Not sure where bottle and fuel pump would go
              activate both w/solenoid valves connected to a single switch on handle bar. Need anouther switch (toggle) some where to arm/disarm system, in-line fuse wouldn't hurt.
              manifold, could be 3/8" SS pipe w/fittings (reg. pipe cheep???)
              jets, spraying systems has SS jets for industrial applications, but not made for fuels (good data on flow/pressure though) if correct flow determined, they might work. (about 6 to $10 ea.)
              Don't know if this would blow up or not though
              _________________________________
              btw Does NZ have a space program?
              If not, maybe the gov. down there could give you a grant for
              starting one. Looking forward to the First XS launch.
              mro
              • mro
                • 4276
                #37
                The Coriolis force/effect, contray to popular beleif doesn't effect drains, but mine spins counter clock wise (had to look)
                • chevy45412001
                  • Mar 2003
                  • 1412
                  #38
                  intake
                  just put the injectors into the vacum ports on the carb rubbers (that ones easy dirrect port )bike bottles are small 1 pound i believe lose the air box and mount were it was now on to nozzles, just break down and buy them,(ya cheap ........) can change the power level as easy as changing jetts in the carbs. as far as seperate fuel pingle sells (makes) dual out let petcocks with addabtor plates 55 dollars for both. couple bits of tubing laying around the shop floor and BANG one XS gernade ready to smoke the 2005 gsx-r1100 in an even race.....lol oh ya for on off hook it into the high beam switch and for warp speed hook it into the horn button. dang i'm a freakin geneius.... with no gramer or speling skills
                  1982 XJ 1100
                  • pggg
                    • 1609
                    • NZ
                    #39
                    From MRO - btw Does NZ have a space program?
                    News just in from NASA.
                    An unusual satellite was spotted circling the equator at low orbit. Observers claim it's shaped like a motorcycle. Astronomer/motorcycle enthusiasts report it as a 'Yamaha XS1100.' Space station astronauts report it has a "dodgy looking fuel boost system of dubious design attached" Experts have no clues as to it's origin.
                    In other news, the chance discovery of a semi-naked individual floundering in the ocean 500 miles off the coast of Hawaii has experts scratching their heads. Fishermen report that the bedraggled and loudly swearing individual was clad in only a crash helmet and scorched leather jacket. Last reported as muttering something about "damn bargain mart fuel hose connecters..." Officials suspect the two incidents may be linked...
                    • mro
                      • 4276
                      #40
                      Oh S#@!, wit from down under that puts one over the top(pun intended), and he rides an XS too!!!!!day
                      And I thought NZ was populated with a bunch of flaming liberals.
                      Just goes to show you can learn something new almost every day
                      btw
                      think my idea will work, just need the expesive stuff, selinoid valves and fuel pump.
                      btw/btw
                      do you know what nitrous costs?
                      mro
                      • xs650mike
                        • 1286
                        • Lake County, California
                        #41
                        Cost of nitrous?
                        Depends mro, do you know any Deadheads who work in a hospital?
                        Shiny side up,
                        650 Mike
                        XS1100SF "Rusty", runs great, 96k miles
                        XS650SJ "The Black Bike", engine from XS650H with 750cc big bore kit, 30k miles
                        Life is not a journey to the grave with the intention of arriving safely in one pretty and well preserved piece, but to skid in broadside, thoroughly used up, worn out and defiantly shouting, "WOW, what a ride !" - [URL="http://www.flyingsnail.com/Sprung/index.html"]Sprung[/URL]
                        • pggg
                          • 1609
                          • NZ
                          #42
                          Cheapo from gas outlets, foundries, welding shops etc.. Best to own a large bottle and fittings yourself. Fill your small bottle at your own leisure then.
                          • mro
                            • 4276
                            #43
                            Almost sounds like a contradiction of terms
                            Doesn't Pat or John work in a hospital?
                            Not sure if their deadheads though
                            btw
                            I've got an account at the local welding supply
                            Would their gas be the same as what you'd want to run in a bike?
                            mro
                            • xs650mike
                              • 1286
                              #44
                              Re: Deadheads who work in a hospital?
                              btw
                              mro
                              They are everywhere, even on this list I bet.
                              Shiny side up,
                              650 Mike
                              • Pat Kelly
                                • 3046
                                • Golden Valley, AZ
                                #45
                                Yes, I work in a hospital. I'm a security officer there.
                                Actually quite ironic considering my previous lifestyle
                                Pat Kelly
                                <p-lkelly@sbcglobal.net>
                                1978 XS1100E (The Force)
                                1980 XS1100LG (The Dark Side)
                                1999 Suburban (The Ship)
                                1994 Dodge Spirit (Son #1)
                                1968 F100 (Valentine)
