drill bits - jet sizes
  • petejw
    • 2269
    • sydney australia
    i remember seeing a thread regarding
    drill bit sizes compared to the equivilent
    jet sizes. i cant seem to find it
    can anyone help me out with the thread
    cheers
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
  • petejw
    • 2269
    • sydney australia
    its ok
    i finally found what i was looking 4.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • pggg
      • 1609
      • NZ
      Pete, mikuni jets aren't rated by diameter eg.. 1.5mm drill doesn't equal a 150 jet.
      • petejw
        • 2269
        • sydney australia
        hey pggg,
        yeah i know,
        but there was a thread in tec tips that
        showed an equivilent drill no for the jet size,
        dnt know how to put a copy of thread on here but this was what i was after.
        For those of you who don't know it, you can drill your jets out for larger sizes instead of spending big bucks to acquire a vast selection. You can also solder the ends closed and redrill them smaller if you are so inclined. Of course, the millionaires among you will scoff at this, so please ignore. Those of you however like me who have more time than money can read on.
        After some surfing I've calculated that you can use the following drill bits to come close to the sizes needed, or actually be bang on with many of them. So here goes. Remember that a jet marked 120 is 1.20mm in size, 135 is 1.35mm etc. Perhaps those who know more accurately can correct me if I'm way out on this, but I think I'm close.
        50____#76
        55____#74 approx.
        60____#73
        65____#71 approx.
        70____#70
        75____#69 approx.
        80____#68
        85____#66 approx.
        90____#65
        95____#63
        100____#61
        105____#59
        110____#57
        120____3/64th's
        130____#55
        140____#54 150____#53
        160____1/16th's
        165____#52 approx.
        170____#51
        180____#50
        185____#49
        195____#48
        200____#47
        205____#46
        210____#45
        220____#44
        225____#43
        230____#43 approx (close to 225)
        245____#41
        250____#40
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
        • petejw
          • 2269
          • sydney australia
          yamaha wanted $25au each for a main jet
          and $26 for pilot jets, i couldnt aford that
          when the drill bit kit costs $28.
          probably wouldnt b any bettr priced in the NZ hey?
          pete
          new owner of
          08 gen2 hayabusa
          former owner
          zrx carbs
          18mm float height
          145 main jets
          38 pilots
          • pggg
            • 1609
            • NZ
            Hey pete, $11.00 each for mikuni jets down here. Get them from any motorbike shop. Yeah, us billionares resize them by twisting the jet onto the drill bit with fingers. Here's a bit of sizing info http://vmaxoutlaw.com/tech/dyno-mikuni.htm
            • petejw
              • 2269
              • sydney australia
              hey pggg,
              thanx 4 the link,
              u wouldnt know the equivelent 4 the pilot
              jet, was wanting to go to 45.
              tiny hole! mite need to buy those.
              4 sum reason with this bike i think i have
              2 buy genuine all the time
              , usually when i need something 4 it
              no one else has it, so i try yamaha first,
              instead of last.
              pete
              new owner of
              08 gen2 hayabusa
              former owner
              zrx carbs
              18mm float height
              145 main jets
              38 pilots
              • petejw
                • 2269
                • sydney australia
                im slow pggg
                so all that info was wrong,
                having to many late nites lol
                so any one know how 2 work out
                the drill bit sizes for the corresponding jets.
                pete
                new owner of
                08 gen2 hayabusa
                former owner
                zrx carbs
                18mm float height
                145 main jets
                38 pilots
                • pggg
                  • 1609
                  • NZ
                  Probably about 3 hair widths! Genuine Yamaha parts pricing calculation sheet - add 100% then multiply by about 10
                  • petejw
                    • 2269
                    • sydney australia
                    so they would still be close enough?
                    havent got the bits yet have jst
                    ordered them ill find the closest 1 that fits then
                    just go up 1 size at a time or mayb 2,
                    once i get the jets sorted out
                    the bike has been running the best since
                    ive had it.
                    pete
                    new owner of
                    08 gen2 hayabusa
                    former owner
                    zrx carbs
                    18mm float height
                    145 main jets
                    38 pilots
                    • edgo
                      • Jul 2005
                      • 138
                      • Tampa FL
                      For my jetting needs I ordered my mains and pilots from Mikes XS650 page. He sells them for $6.00 a pair and if your order is over $35.00 shipping is free and it is next day shipping. Pretty good deal.
                      Ed
                      79 XS1100SF
                      78 YZ400E
                      81 SR500
                      79 RM250
                      77 YZ400D
                      05 RM250
                      78 CR 250 Husky w/TT500 motor
                      • mro
                        • 4276
                        • Hayward, California
                        hey petejw
                        "so any one know how 2 work out
                        the drill bit sizes for the corresponding jets."
                        good luck, fluid dynamics/chaos theory are beyond me
                        the difference between the numbered 140 jet and the dyno equivalent size is about 6.428% and the % seems to change with other sized jets.
                        mro
                        • pggg
                          • 1609
                          • NZ
                          Well, a 1.5mm drill wont slide thru a 142.5, does slide thru a 147.5 with a tiny tiny sideways slop, my 145's are in my bike so can't accurately say - but a 1.5mm hole in a mikuni would be damn close to the standard 145 mikuni jet.
