Oh No!! I've got a big problem!
  • Shawn27530
    • 63
    • Goldsboro NC
    I bought a new battery, installed it in the bike, and went to turn it over. And nothing it was like the starter hit a brick wall. I was going to pull a compression test as with all bikes I get. So I pulled all of the spark plugs, sprayed a whole can of liquid wrench into all the cylinders and let it sit for a beer while I cooled off and retrieved my screwdriver that flew out the garage door. I pulled the stator cover off and the crank would not make a full revolution either way aprox 3/4ths of a turn. At first I thought it might be a broke rod or wrist pin. So I stuck a long screwdriver into each cylinder while I turned the crank, all pistons are moving up and down as I turn the crank back and forth. It gets to a stop and won't go any further, the flywheel bolt breaks loose first. Any ideas what I have got myself into, I knew I should have spun it over before I bought it. But it had a dead battery and such so I just loaded it up and brought it home. Man this is such a bummer.
    1980 XS850G
    1978 XS750SE>>>>>Sold
    1982 XJ1100 Maxim
    • 5069
    Quit forcing it.
    Remove the cam cover and see if you are lucky enough to line-up the arrows on the cam bosses with the dots (holes) on each cam --- without forcing it.
    Where am I going with this? You may have slipped the cam chain. Contacting a valve with a piston crown is bad for valves and forcing it can actually damage a piston.
    • 2bhappy
      • Sep 2005
      • 73
      • Flint, Texas
      Shawn,
      My guess is that you have a bent or stuck valve that is not allowing the piston to complete its cycle.
      Marc
      • Shawn27530
        • 63
        • Goldsboro NC
        Ok, I will pull the valve cover tomorrow for a better look. I called the original owner this afternoon, a fellow military man, he said he bought it right out of the crate, and it was running good when he parked it to go to Alaska.
        1980 XS850G
        1982 XJ1100 Maxim
        • petejw
          • 2269
          • sydney australia
          Hey Shaun,
          That happened to me not to long ago,
          the result, 4 bent intake valves,
          the chain had jumped a cog while i was cranking it,
          the motor would still turn over if i cranked the engine
          with the starter, but i couldnt turn the crank over by
          hand.
          the valve was protruding enough that when i removed the
          spark plug i could c it hang over.
          Its not a pretty site seeing 4 bent intake valves.
          Prior to changing the battery did u do any work on the
          motor, adj cam chain?
          Do what skids says and remover the valve cover and see
          if the dots line up.
          Good luck with it.
          pete
          new owner of
          08 gen2 hayabusa
          former owner
          1981 xs1100 RH (aus) (5N5)
          zrx carbs
          18mm float height
          145 main jets
          38 pilots
          • prometheus578
            XS-XJ Super Guru (RESIGNED)
            • Aug 2004
            • 4012
            • Olympia , Wa.
            with the valve cover off, check the valve clearances. Sure... you can't spin it completely, but check them anyway when the lobe's pointing away from the shim. HHmmm... you didn't mention what kind o' bike this was. maybe you don't have shims... but you get the idea. You may have a coupla real crazy readings.
            I had a bent exhaust valve... the clearance was .035. Not too bad... not bad enough to stop a piston.
            If you've got bent valves and they're hitting the pistons, you should see some compressed valve springs and REAL loose clearences.
            • petejw
              • 2269
              • sydney australia
              heres a cpl of pics of the head from my bike.
              and it worked lol
              there is no cam at the back of the head.
              pete
              new owner of
              08 gen2 hayabusa
              former owner
              zrx carbs
              18mm float height
              145 main jets
              38 pilots
              • petejw
                • 2269
                • sydney australia
                sorry i didnt think the pics were that big.
                pete
                new owner of
                08 gen2 hayabusa
                former owner
                zrx carbs
                18mm float height
                145 main jets
                38 pilots
                • Shawn27530
                  • 63
                  • Goldsboro NC
                  I went ahead and pulled the valve cover last night, because curiosity was killing me. The only valve springs that are compressed are the ones that should be open with the cam lobes down. I can lift the cam chain up off of the guide a little.
                  But now the engine will not budge either way. I was thinking maybe the transmission has it locked up somehow, but it shifts through all the gears and goes back to neutral.
                  I'm thinking boat anchor!!
                  1980 XS850G
                  1982 XJ1100 Maxim
                  • LoserShoes
                    • Apr 2005
                    • 524
                    • Bangor Maine
                    Have you tried it with the clutch pulled in? That will eliminate the transmission as a problem.
                    Steve
                    73 Yamaha DT3 - DirtyHairy
                    CZ 400 MX'er
                    68 Ducati Scrambler
                    RC Planes and Helis
                      I recently had to drill a broken spark plug from the head of the 79SF that I am working on, and I noticed that the valves can be seen if they are just slightly open. Use a good bright light and look inside the spark plug hole. If a valve is stuck open, you should be able to see it.
                      • Shawn27530
                        • 63
                        • Goldsboro NC
                        Alright I am convinced it is a transmission problem. I looked in all the spark plug holes and all the valves seem to be ok. Pulled the clutch lever in and zip tied it to the bar. Still the engine will not turn. I put the transmission in gear and the rear wheel won't move either.
                        1980 XS850G
                        1982 XJ1100 Maxim
                        • pggg
                          • 1609
                          • NZ
                          Seized starter motor?
                          • Shawn27530
                            • 63
                            • Goldsboro NC
                            Thats my next move, is to pull the starter motor. When I hit the starter you can hear it bump, but can it be that the gear is still engaged? I will find out tomorrow.
                            1980 XS850G
                            1982 XJ1100 Maxim
                              The gear on the starter shaft is always engaged with the starter clutch, which is in the engine case. The gear does not spin on the end of the shaft like it does on most auto starters. It is fixed in place. Try removing the starter, and turn it over by hand useing the 19mm square flange that is under the ignition cover. That way the bolt won't tend to loosen when you are turning the engine over. You could always remove the clutch cover and disassemble the clutch. That would eliminate transmission from the equation.
