ignition unit
  • KJK
    • 20
    • Corpus Christi
    ignition unit
    Does anyone know a way to check an 81 XS1100 Special ignition unit P/N 4R0-10. I think this is the problem BUT would like to test it before looking for a new one. I just bought a Clymers manual. These are great books, but do not go into this part.
    Thanks
    Kevin
    1981 XS1100
    Eleven Special
    Hey there Kevin,
    Check out this link, Randy the resident electronics GURU has info on how to test your TCI!!
    Randy's Web Site
    • 2bhappy
      • Sep 2005
      • 73
      • Flint, Texas
      Hey TopCat,
      Randy is "forbitten fruit" LOL. I get a response that I have to have permission to access his site.
      Marc
      • randy
        • Dec 2003
        • 4521
        Marc, he just gave you the wrong url. No password required, I've changed the url within the past year, so i guess TC gave you the old one. here you go:
        randy's XS page
        • 2bhappy
          • Sep 2005
          • 73
          • Flint, Texas
          Thanks Randy,
          This URL works. Just curious. Is it possible to use a TCI unit to ignite the coils of a Triple and have it function properly or is the CDI unit spark more intense than the TCI?
          Marc
            Hey Randy,
            Thanks for the update, I had just copied it from the LINKS thread, didn't know you had changed it!
            Marc, if you're talking about the TRIPLE XS750's and 850's, then I would think that they would NOT work with the XS11 TCI. They are all TCI's, not CDI's! But even if they were, you can't use CDI's in place of TCI's, the ohm range for the coils is very different, and you'll fry a TCI when used on a CDI machine.
            The TCI's don't send out any kind of spark power, they just act as TRIGGER mechanisms for the ignition coils. They do control how long the circuit is open before it collapses which does contribute to the power the ig. coil generates.
              Hey Marc,
              I just reviewed the parts fiche for the triples, they use this interesting 3 sided pickup coil wire assembly. They have 1 ignition coil with 2 wires and 1 ig. coil with 1 wire. I would imagine that the PU coil is wired to trigger the dual wired coil twice for every once of the single wired one utilizing a wastespark design.
              I would think if you could figure out the PU coil wiring that you could get an xs11 TCI to work on a 750/850!?
              • 2bhappy
                • Sep 2005
                • 73
                • Flint, Texas
                TopCat,
                Maybe Randy can shed some light on this. I am going to dig deeper into this possibility. When you are retired and old, you dream up thingd to do LOL.
                Marc
                • LoserShoes
                  • Apr 2005
                  • 524
                  • Bangor Maine
                  So how can you have a triple with two pistons at 180, degrees to each other? I can't imagine any one would design a triple with a pair of pistons that went up and down together, with a third at 180. I thought they all had to be 120 (0,120,240) degrees, which makes a shared coil not a possibility.
                  Please tell me that Yamaha didn't do it.
                  Steve
                  73 Yamaha DT3 - DirtyHairy
                  CZ 400 MX'er
                  68 Ducati Scrambler
                  RC Planes and Helis
                  • 2bhappy
                    • Sep 2005
                    • 73
                    • Flint, Texas
                    I was not talking of using shared coils, in fact I never mentioned the use of the 1100 coils.
                    Marc
                    • randy
                      • Dec 2003
                      • 4521
                      Let me be the first to dispell the myth that I might know how to make an XS11 iggy work on a triple!
                      I believe the 120-120-120 degree phasing is correct, that would explain the three pickups on the triple. But that's as far as I'll go.
                      • 2bhappy
                        • Sep 2005
                        • 73
                        • Flint, Texas
                        If the XS1100 iggy has TWO outputs that trigger the two coils that fire the cylinders then I figure I can connect one input from the pickup coil to on of the inputs on the iggy and the corresponding out put to cylinder coil number 1 on the Triple, now comes the iffy part. I connect the next two pickup coil outpputs to the second iggy input an have a smart fella device a flip/flop gate that will alternately send a signal to each of the remaining two coils and walla, I have a device taht will work 3 or 4 cylinders.
                        I think I will just monitor ebay and stock up on a couple of Triple iggys...............
                        Marc
                        • KJK
                          • 20
                          • Corpus Christi
                          Thanks for the link and Randy you have an awsome web site. Is there a test that can be done on the TCI without being connected?
                          I ask because I had an intermitent (2 seconds) stalling, but now it does not run. Also the starter does not turn using the start button, but will if jumpered with a screw driver. I'm wondering if jumpering the starter will give me false infomation when checking for spark at the removed spark plug.
                          Kevin
                          1981 XS1100
                          Eleven Special
                          • randy
                            • Dec 2003
                            • 4521
                            KJK,
                            Sounds like a fuse problem. Check the main fuse and connectors. If you have the original glass fuses, sometimes they can break inside and still LOOK good.
                              Hey Marc,
                              My bad, the diagram for the 750 wasn't too clear, and I'm surprised some of the Triples folks ie. Pat Kelly, didn't jump in and correct me! The triples actually use 3 individual coils. The pair up front looked linked at first, that's what confused me, but the parts list says the same part number for all three!!! So...yeah, like you said, best to get some spares off of ebay!
                              Kevin,
                              Like Randy said, check those fuses, but also you may need to check your main ignition key switch. Also, your starter solenoid may be bad, you can run a test GROUND wire from it to a good ground to see if that will cause it to engage, cause that's all the starter switch on the bars is....a wire that completes a circuit to ground. Just find the small wire coming off the solenoid that goes to the handlebars. One of the small wires will be a HOT, the other the ground to the bars switch. Also, is your battery fully charged? Have you checked and cleaned up ALL of the battery connections and grounds to frame?
