Hello.
I am having troubles with my XJ. When I first got the bike it had sit-itis. ('82 model... 5,000 miles) When I finally got it running with some good gas, it was hard starting first time of the day, then good after that. The only real problem, was that after it warmed up good, when you came to a stop, the motor wanted to rev way up to about 4 grand with the clutch in. It didn't do this while it was cold. I was told it was probably the slides in the carbs a little bit gummy, and if I ran some MMO in the gas for a bit (4 oz per 5 gallon), it would clear it up. I ran it several hundred miles, never did clear the rev-up problem, but now it has gotten dang near impossible to start.
I adjusted the cam chain tensioner, and it is almost ALL the way into the motor. I am surpised the retaining bolt got any of it to hold. I got curious and checked the compression on it and it SUCKS!! 55, 65, 85, 80 pounds, 1,2,3,4 respectively. When I went to check the valve adjustment, the #1 cyl wouldn't even let the .04mm feeler in! The other 3 were less than .10mm. All the exhaust were between .10-.15mm, so they are way too tight also. I realize I need to shim these, but where do you start on the #1 when it is obviously riding the cam the whole time? I have the chart in my manual, and it tells what to use, but is there a way to measure something and get precise if it IS touching?
Do you think that by running MMO in it, I have carboned up the valves? I have since been told that my rev-up problem is maybe ther starter jet on the carbs? I took the carbs off a while back and tried to clean up the slides in the carbs with some emory cloth, even though they looked fine, but I didn't feel comfortable messing with the jets or anything. I just took the main jet out and looked to see that they were clear. I have installed some inline filters, but the carbs really looked fine. (No trash and such).
So.... do I attempt to tackle the possible carbon problem, or just shim it up and check it again later. (With no MMO) The shimming seems easiest, but seems I will be doing it again if I get the carbon burned off. I am taking the carbs out again for a complete cleaning, so that will rule out Starting jets. What about my cam adjuster?? Stretched cam chain already? Bad cam chain guides? The top one between the cams seems ok.
So many questions, so little time! I don't care if it's in the low 30's I WANNA RIDE!!! Anyone help me get back going?
Thanks to everyone on here, this site is great!!
P.S. I have purchased a mostly complete motor and trans, but no nothing about it really, other than the guy said it "Checks out good". Should I abandon this 1st motor for a bit and try the other I know nothing about, or try to fix the one I know was running???
