Holes in the exhaust (on purpose)
  • mixelpix
    • Sep 2004
    • 237
    • Utah
    I've seen a couple different XS's (and other bikes) out there with holes drilled into the back plate of the muffler - gives it a little more grumble(?). Just wondering if this is a significant enough of a modification to warrant rejetting/tuning the carbs? Or is it something which might make the exhaust worse off?
    Thanks!
    Your Mileage May Vary
  • bandet01
    • 698
    • connersville indiana
    well i pulled the baffles totally out of my stock pipes and didnt have to mess with the jets but i am getting a 4 into 1 header and i am sure i will have to rejet it for that so i wouldnt think drilling holes would have to make you have to rejet your carbs
    79 yamaha xs1100f standard
    best 1/4 mile 13.282@99.40
    • xs650mike
      • 1286
      • Lake County, California
      A common mod in the XS650 and Harley worlds is to use a tapered rod to break the last baffle loose and fold it against the core pipe which increases the rumble factor significantly without necessitating a rejet. Anybody out there done this to their stock XS11 exhaust system?
      Shiny side up,
      650 Mike
      XS1100SF "Rusty", runs great, 96k miles
      XS650SJ "The Black Bike", engine from XS650H with 750cc big bore kit, 30k miles
      Life is not a journey to the grave with the intention of arriving safely in one pretty and well preserved piece, but to skid in broadside, thoroughly used up, worn out and defiantly shouting, "WOW, what a ride !" - [URL="http://www.flyingsnail.com/Sprung/index.html"]Sprung[/URL]
