valve noise or tapping spark plug
  • speedlimit85
    • Jan 2017
    • 494
    • Gainesville, Fl.
    So I heard different noise yesterday. I looked around at idle and saw a spark plug was loose 2nd from the left. I tightened it and ran the bike again, the noise is like a tapping louder by that plug. Maybe I should change the plugs and have a better look.
    80 G
    • 8964
    Could be a few things...
    Faulty or loose spark plug, cap or wire. The spark arcing to ground can make a ticking noise.
    Loose exhaust header. Lets the normal ticking valve noise escape and seem much louder.
    Probably not the valve adjustment if it just started happening.
    If you are able to run the engine in a dark garage, you should be able to spot any spark arcing.
    • speedlimit85
      • Jan 2017
      • 494
      • Gainesville, Fl.
      Hmm. Changed plugs and as I was riding around it occurred to me, a different tank makes noise carry other ways. I hear the vacuum sound too a bit different. I may have over reacted cause that one plug was loose. The 2 inside wire caps have some play but seem ok. I'll keep an eye out for other loose stuff.
      80 G
        • 301
        maybe the cam chain adjustment,,,unless you have the automatic cam chain adjuster...if the cam chain is loose it makes a tapping noise, try to adjust it if it hasnt been done in the last 5k or so.....Mike in S.Diego and Pa.
          • 8964
          Hmm, that's interesting, does one tank have some kind of coating on the underside to deaden the sound? That may be something I may try some day.
            • 7844
            It may be the difference between a standard and a special tank. If you really want to hear different things, put a fairing on the bike!
              • 3375
              ^^^Ain't that the truth!^^^
              2001 ZRX 1200
              1982 Seca 750
              1983 Nighthawk 550
              • speedlimit85
                • Jan 2017
                • 494
                • Gainesville, Fl.
                I got the auto chain tensioner awhile back. Maybe it's between notches?
                80 G
                  • 8964
                  I don't think it can go between two notches. If you really want to check the chain tension, it requires removing the valve cover and pulling up on the chain at the center bridge. There should be about 1/4" of travel if the tension is correct.
