So now that I got my Jeep back along with the junkyard engine (which is runninng great) I can finally work on the bike. Today I went to my storage unit and actually took off the brake caliper so I can replace the seals. I tweaked a shoulder muscle at my job after I fell, and decided to just take off the caliper and do the seals on a workbench. I have a spare caliper in its place so the brake fluid wont get all over.
Brake caliper update
1997 Jeep Cherokee 4.5"lift installedTags: None -
Ok I was able to get the piston out using an air compressor. I do have a nick on the piston where the boot goes-should I file or sand it down or just replace it? The pistons on my bike say SS are my to assume it is stainless?1980 XS1100 SG
1997 Jeep Cherokee 4.5"lift installed -
Yes, I would say sand it with 600-1000 grit and if it smooths out, then your ok, if not, replace. Yes, the Special front caliper pistons are stainless.
Also, if the nick is outside of the square edged seal when the piston is fully compressed, then you should be ok.Last edited by bikerphil; 11-22-2026, 07:44 PM.2H7 (79) owned since '89
☮👍 1Comment
Agree, if it's outside of the outermost seal, and the piston is seated at full depth and the nick won't reach the seal, you're fine. From experience.
With that said, crocus cloth is fantastic for that. Picked up that trick from a forum member here a long time ago. Takes some time but leaves a super smooth finish.Last edited by Bonz; 11-23-2026, 07:24 PM.Howard
2001 ZRX 1200
1982 Seca 750
1983 Nighthawk 550👍 1Comment
I have that in my tool boxes in my Moms garage. I have off now for Thanksgiving and dont go back to work until Monday1980 XS1100 SG
1997 Jeep Cherokee 4.5"lift installedComment
As you know, if the imperfection in the piston goes below the seal, it gets fluid in it and when the piston is pushed back out, the fluid goes beyond the seal. That's where a "leak" comes from.Howard
2001 ZRX 1200
1982 Seca 750
1983 Nighthawk 550Comment
