Confused about brake pads
  • Ccitis
    • Jun 2023
    • 213
    I am having a hard time figuring out what pads I need for my 80G. FA34s in the back... but what about the front? Are the left and right different or is that only on the special? What exactly do I need.
    • 8930
    All Standards use the same brake pads front left and right and rear. Only the Specials have a different pad for every caliper.
    FA34 will fit all caliper positions on the Standard, all years.
      • 296
      just got these for my xs,,,,good value, good stopping power,,,both front and rear pads,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,ebay Brake Pads for Yamaha XS1100 1978 1979 1980 1981 Front Rear Motorcycle Pads
      CALTRIC Largest Selection of Quality Replacement Parts
      Caltric
      (1538593)
      99.6% positive
      Seller's other itemsSeller's other items
      Message
      US $21.31/ea
        • 8930
        When you do install the new pads, make sure the tip of the small inboard caliper screw fits thru the small hole of the pad. Some brands need drilling out I have found.
        • Ccitis
          • Jun 2023
          • 213
          I had to drill out the EBC F34s. I am chasing an issue where the front brake lever is extremely wooden most of the time... with very little play... and then other times it goes softer. I have cleaned the little return hole a few times. The brakes squeal bad too. I have a front end vibration at high speed, I am wondering if the brakes are slightly dragging having just replaced wheel bearings and tires.
            • 837
            Might not be a bad idea to take a look at your caliper pistons to see if they're moving freely, it's not that hard to pop them out and give them a polish with 600 grit paper followed by 1500.
              • 8930
              Have you removed, disassembled and thoroughly cleaned the master cylinder ever? Brake fluid crystalizes around the piston over time and can make the lever feel tough. Did you upgrade to SS braided brake lines without changing the master cylinder piston size?
              The high speed wobble could be from loose steering head bearings.
