Advice needed
  • PlustinChesil
    • Nov 2025
    • 1
    Advice needed
    Got an older xs1100 that pops off and sounds like **** but does go. It needs a booster to turn over (one that has a 12volt boost) and even then it struggles to turn over. I opened the starter up and it looks old for sure but works as it should. Any tips?
    Here's the best advice I can give. Get a repair manual and go though every maintenance step regardless of age or mileage, by then if it still doesn't run right (and it probably won't) you'll have a better idea of what questions to ask!
      Yes, service steps. Service the motorcycle nose to tail.
      Starters can be overhauled. There’s no point in doing that if you haven’t load tested the battery. On a machine this old, wiring issues like corrosion are also likely. Etc etc
      Service the bike.
        Originally posted by PlustinChesil
        Got an older xs1100 that pops off and sounds like **** but does go. Any tips?
        Yup! (^_^)
        Very common to find these bikes in this condition. ( •_•)
        Possible/LIKELY that the previous owner bought it cuz it wuz a "SuperBike", went thru it to get it running-Cleaning carbs, new battery, etc... (⊙ᴗ⊙)
        Then found it ran like garbage- popping, spitting, backfiring, bogging down, etc. (Θ︹Θ)
        NOT the "Superbike" experience they wuz lookin' fOaR.... (*′☉.̫☉)
        They park it and forget about it fOaR a year until the carbs are re-gunked, battery wasted, and the air in the tires is gone. (☉_☉)
        Next person buys it thinking it only needs a carb clean and a new battery- Superbike! \(^_^)/
        Same "Lather-Rinse-Repeat" happens until someone finally yoinks out the Ebay/Amazon junk carb jets/parts from Taiwan/China and installs genuine Mikuni. (-‸ ლ)
        To the victor goes the spoilz! \(•‿•)/
          • 2104
          Along with the XScellent advise above, now that you know the engine runs, hopefully with no weird sounds, you can go over all the electrical, complete fuel delivery system, front and rear braking systems, all the lubrication from top to bottom and if the tires are decent you should be able to take her on a short shakedown jaunt to see what needs attention next.
          A pic or two,three or four would let us help you more proficiently.
          Welcome to Club 'leven !!!
            Start with a brand new battery and a full carb overhaul & sync.
              Tip #2? (O_o)
              Iffin' you want that "Service Manual" fOaR yur bike....they're on this site and FREE. (´◡`)
              The "digital" version o'course. No dog-eared pages or greasy smudges all over the impor'unt parts. (¬‿¬)
              Yur journey begins wit' those three legendary/fairytale questions you gotta answer to move onwards.... (-‿◦)
              Make? Model?? Year??? (⊙_☉)
                Everyone has given great advice and here is a link to get a copy of the service manual. Ringler.us | My Bike
                  Check to see if the "mixture tips" (aka pilot screws), any or all of them, have broken off in the tops of the carbs. Also perhaps the pilot screws may have been from a non-Micuni rebuild kit.
                    Pilot screws from the kits will work, it's the JETS that are a problem. I use the screws, just NOT the jets unless they are Mikuni.
                      Profile shows he owns an 80 XS11. Doesn't say Special or Standard; I think the carbs were the same and were the later carbs. The pilot screws were not as big problem about breaking off as they were in the earlier carbs. Like Ray I have used after market pilot screws in many carbs with no problems. It is those pilot jets that cause issues. I have actually played with those and with effort can get them dialed in but still prefer Mikuni OEM.
