Spacer on rear axle '81 SH (Special)
  • Tex
    • Aug 2002
    • 10
    • Camp Wood, Texas
    I bought this great bike used. Never saw it new.
    Clymers shows a spacer(like a fender washer) between the frame and the axle on the right side.
    The book covers many models therefore it may be suggesting a part that does not belong on my bike.
    I hope so because I don't have one.
    Do I need one?
    Thanks,
    Tex
    If everything looks okay without a washer, (i.e. no gaps along the axle) it probably is. Just check to see that the caliper assembly centres properly on the brake disk.
      • 5062
      Re: Spacer on rear axle '81 SH (Special)
      Tex
      You might be referring to the spacer that looks like a thick washer with a groove around the center and that has a slight ridge (I think) to keep it centered with the caliper bracket?
        Tex, here's the photo you sent me off-line:
        Here's a shot of the same place on my '80 Midnight Special:
        It looks like you've got all the right parts, but still have a gap.
        This got me curious, so I went out and had a look at my '81 Standard:
        Hmm, similar gap, maybe I need a spacer too? OTOH, by loosening the pinch bolt and giving a bit of a grip with big pliers, that gap basically disappears:
        Maybe neither of us needs another spacer, just need to close up the gap and re-torque the pinch bolt. It's certainly not like it took much of a squeeze to bring the right swing arm over that small of an amount.
        • Tex
          • Aug 2002
          • 10
          • Camp Wood, Texas
          Ken,
          I really appreciate your obvious interest and effort. I'll give that a try. Sometime I feel a little slop in the backend I wonder if that is the cause. I'll check it out and let you know.
          Thanks again.
          Jim (Tex)
