Leaking Front Right Rubber Brakeline! (ノ_<。)
  • Filter
  • #16
    Those kits from XJ4Ever are well worth any premium you might pay. The installation is fool proof. I have the same on my bike.
    • #17
      Originally posted by DEEBS11 View Post
      Nice job Larry. I had my Motoguzzi breech in the same spot under a rubber clamp while on a trip hundreds of miles away from home with my wife on the back of the bike. Had to ride all the home with one front brake only (linked system rear/one front). Gotta watch out for old rubber lines.
      Thx! (◠‿◠)
      On my "Continental Trips" I had spare rubber lines just in case. I even got an extra/third set from Andreas Weiss when I cleaned out some of his last inventory a while back. (ʘ‿ʘ)
      But I just couldn't bring muhself to install'em in this situation fOaR some reason... (≖ ︿ ≖ )
      Note- Seems fitting that the leak/break happened at or near that clamp. (⊙▂⊙)
      I mean, when I'd squeeze the lever I'd see the lines plump up like a Ball Park Frank everywheres BUT near those clampz. (*´-`*)
      • #18
        I put SS lines on my touring XS11 decades ago. Bullet proof but as noted, the feel really is different - firmer and less give. More like on or off. After decades I decided to go back to NOS lines I had preserved. Softer feel and seems to have a more nuanced control over breaking. Both are fine, just different.
        78 XS1100E touring
        78 XS1100E stock
        80 XS1100LG Midnight Special
        83 XV920MK Midnight Special
        83 XJ750MK Midnight Special
        83 RX50 Special
        97 FLHR
        • #19
          Yup...Very much different. (°_°)
          Just got back from a run to Der Weinersnitchel (5 chili dogs fOaR 5 dollars..) and first thing I did when I got back was adjust the lever position so it matched the travel/sweet spot of my hand/fingers. (~‾⌣‾)~
          Old rubber lines remind me of when I had cable brakes and the cable was a bit s t r e t c h y. Brakes would engage and then I'd keep adding pressure till the cable stopped stretching and the grip felt HARD. ( /・・)ノ
          SS lines are like NO stretchy at ALL. Wut you squeeze it wut you get. ( ノ・ェ・ )ノ
          STRANGELY.... Imma thimkin this might just be adjustable. ¯\_(ツ)_/¯
          Y'know hows lots of newbies begin their posts with "My front brakes are spongy" or "Can't get the air out of front brakes."??? (O_o)
          The "cure" seems in contention. I mean some advise squeezing the lever half-way and waiting over night. Others say MIGHTY VAC is the solution. Other options I can't recall. ┐(‘~`)┌
          I can say that NONE of those options above have ever worked fOaR me. (´~`ヾ)
          Wut DO wurky???
          I unattach the MC from the handlebars, install a PLUNGER handle in the mount, point the front of the MC DOWN, and then squeeze the lever a few times. ヾ(⌐■_■)/
          Wut imma sayin' is that depending on how much of the air one gets out of that "high point" (front banjo bolt/front section...) the firmer the lever feels. ( ̄ー ̄)
          I went whole hawg and bled all the air out so's the lever is hard as a rock but I could'a stopped somewheres in between. (︶‿︶)
          Not an EXACT method but depending on how big that air bubble is would add a little mOaR "softness" to the system. ٩(⊙‿⊙)۶
          • #20
            Been a while since i saw anyone post about those lines. How well did they fit for you? I worked with Chacal (Len) to make those and we went back and forth quite a few times before we had the exact fit. I had one of every North American model at the time so I could easily fit them up and make any changes needed. So glad to see em posted up again. Thanks Larrym
            • #21
              A 16mm master cylinder on a Special will give good linear lever feel and plenty of stopping power. Leaving air in the system doesn't sound like a good idea, JMHO.
              • #22
                Thank YOU, Rasputin. \(^_^)/
                I mean I know that somewheres peoples figured out how to make these lines wurky. Just some random unsung heroes who cooperated together and Imma benefitting frum the end result of their efforts. ( •_•)>⌐■-■
                bikerphil,
                Not a fan of air in brake lines OR hydraulic lines either. ( ゚_ゝ`)
                Hence the toilet plunger handle heroics to get the air OUT....
                ALL of it. (︶︹︺)
