XS850 Service Bulletin Thread
  • XS850GUY
    • Dec 2024
    • 15
    XS
    XS850 Circuit / wiring diagram
  • XS850GUY
    • Dec 2024
    • 15
    xs850 neutral relay safety circuit
    • XS850GUY
      • Dec 2024
      • 15
      XS850 Ignition Circuit Relay Mod
      • XS850GUY
        • Dec 2024
        • 15
        XS850 Ignition Circuit Relay Mod:
        Before:
        After:
        • XS850GUY
          • Dec 2024
          • 15
          XS850 / 750 Valve Shim Chart
          • XS850GUY
            • Dec 2024
            • 15
            XS850 Flasher/Canceling Relay Mod
            • XS850GUY
              • Dec 2024
              • 15
                • 2053
                Thanks for the info.
                Those service bulletins don't seem to be issued by Yamaha, considering the dates are within the past month?
                • XS850GUY
                  • Dec 2024
                  • 15
                  Hah! Certainly not!
                  I created them because info regarding these topics is sparse & I'm giving back as I make discoveries and progress. They are as much for my own benefit as the community at large.
                  • XS850GUY
                    • Dec 2024
                    • 15
                    Further detail on the Flasher Relay and Flasher Cancel unit. Although partnumbers may vary, these basic concepts should apply to most any yamaha street bike of this vintage that includes the flasher cancel unit. Enjoy!
                    • gtem
                      • May 2023
                      • 230
                      • Indianapolis
                      I'll have to point my brother to this thread (his main bike for the last 4 years has been a '79 XS750F)
                      '98 GSF1200S
                      • XS850GUY
                        • Dec 2024
                        • 15
                        Success! Here's the xs850 gearwheel stack out of the bike. No split cases, no exhaust pull.. So far pretty easy, besides research and mental prep.
                        With the transmission drive axle end bearing cap off, the 2nd gear wheel can come out w a snap ring pliers. However the 5th gear wheel is held captive by the #3 shift fork. To release the 5th gear wheel, you need to pull the clutch basket & oil pan. Then from below remove the e-clip from the #2,3 shift guide fork then slide out to release the #2,3 shift forks. Then the 5th wheel can slide out the end bearing cap opening.
                        Next, to remove the entire gearwheel stack the drive axle carrier bearing cap needs to be pulled.
                        There are 2 things stopping the bearing cap from popping right out;
                        A: #2,3 fork guide shaft needs to be fully retracted to clear the bearing cap,
                        B: Oil pump also needs to come out. 3 cap screws hold the pump to the lower case. Two of them are obvious and accessible as soon as the oil pan is off. The 3rd is hidden behind the pickup spout.. so. 3 JIS screws to remove the screen, then 2 small cap screws to remove the spout, then you can get at the 3rd fastener.
                        The gear dogs on the remaining gears also showing similar wear to the 2nd/5th gears that I already pulled.. Likewise, the #3 gear fork is very worn.
                        I'm this deep already, and since everything is apart, I went ahead & ordered a complete set of NOS gearwheels & the #3 fork which was pretty worn also) Total spend for the 1-5 gearwheels+#3fork, $460.05
                        Total spend on the bike so far, including everything, purchase price ($200), registration, repair/replace parts, fully rebuilt brakes/MCs w new pistons & all new spiegler lines + a bunch of NOS/Rare spare parts that I'll keep in stock, $3,486.69
                        Doing pretty good so far and once buttoned up I'll have a basically brand new gearbox.
                        • XS850GUY
                          • Dec 2024
                          • 15
                          The custom 750 ->850 2nd gear wheel bushing/mod is finished!
                          Def tighter tolerance vs the worn (23.3k mi) oe gearwheel.
                          My oil relief scratch pass turned up a burr, that I had to sand back by hand w 320, (Paul Brodie, & his student, "fine fingering", look it up).
                          I called it there, tho could have gone a few thou deeper for oil relief, shrug, 4tpi is wildly fast, even in back gear, oof (lathe people will know *eyeballs*)
                          Should be fine & nice thing is I have plenty of bearing bronze left over.
                          I also have another spare/untouched/NOS/NIB 750 2nd gearwheel instock, plus 2 nos revs of the mated 5th wheel!
                          The bushing pressed in neatly & bottomed against the shoulder perfectly.
                          The proud boss, on the 750 wheel, turned perfectly on the lathe 2-3 thou at a time (see previous posts for dimensions/detail, XJBikes Forum).
                          So pleased! Still need to do final assembly & test flight... fingers crossed...
                            • 1757
                            That's quite a repair. My compliments to the chef.
