Brake master cylinder diaphragm busing
  • aquamantx
    • Aug 2015
    • 198
    • Montgomery, TX
    Who did you order the kit through?
    81 LH in process
    09 vstar 1300
    only allowed 2
      • 1647
      ..........Click image for larger version
Name:	Rear brake mc kit.jpg
        • 1864
        If you will notice in the description of what this kit fits it specifically states it does not fit the 81 Midnight Special, which it doesn't. The only place that I found that supplies the parts needed to refresh/rebuild the rear master on the 81 LH is from Xj4ever.com
        • aquamantx
          • Aug 2015
          • 198
          • Montgomery, TX
          Thanks for the info. The folks over at XJ4ever are helping me sort it with a kit. Great place for parts and great people to work with. The one year off bikes are fun to find parts for.
          81 LH in process
          09 vstar 1300
          only allowed 2
            • 1864
            The specific kit they carry is HCP26520. You can search for it in their catalog, which is thorough but hard to navigate, at XJ PARTS CATALOG, SECTION J: BRAKES Rear Brake System Parts
            Description on their site:
            HCP26520 Aftermarket rear MASTER CYLINDER BASIC REBUILD KIT for all 1981 XS1100 Midnight Special models. Contains both fluid seals, the c-shaped piston retainer, the retaining snap ring, the plunger rod rubber dust boot, a glass fluid level sight window (requires the use of our HCP3120 or HCP3120A sealant for proper installation), and a packet of brake assembly grease. Note that you will need to re-use your original piston and return spring, which are not included.
            $ 89.95​
              • 1647
              Does the 81 have linked brakes? They all seem to have the same MC.
              Click image for larger version  Name:	XS11 rear brake kit fits all models.jpg Views:	0 Size:	248.9 KB ID:	884417
                • 1864
                81 LH still not covered by this kit. The LH is a unique animal. It does have linked brakes. The rear and front left caliper are actuated together by the rear master. There is also a proportioning valve linked from the master that plays a factor in how much pressure is allocated to the front and back calipers. The rear on this setup is not the same as other year rear master's. Probably why no one does a kit for it. Chacal over at XJ4ever addresses the parts needed for a refresh with the caveat being you have to reuse the rear master piston and return spring. If those are toast then you have to find a replacement, which we all know are getting harder to find.
                  • 1647
                  OK. This is the exact part number (edit: For all other models). Must be larger for linked brakes (LH).
                  Click image for larger version  Name:	80 81 Midnight Special.jpg Views:	0 Size:	255.4 KB ID:	884420
                    • 1647
                      • 1647
                      I think that diagram might be wrong. It does not show the front brake line. Must be a typo. (edit: Midnight Special is the LH version with linked brakes)
                        • 1864
                        .......... Click image for larger version  Name:	81 kit.jpg Views:	0 Size:	179.7 KB ID:	884422
                        It is different and is a different part number. Yamaha Motorcycle 1981 OEM Parts Diagram for Brake | Partzilla.com
                          • 1647
                          Oh...LH! Got it.
                          • aquamantx
                            • Aug 2015
                            • 198
                            • Montgomery, TX
                            Yes the brakes are linked.
                            81 LH in process
                            09 vstar 1300
                            only allowed 2
                            • aquamantx
                              • Aug 2015
                              • 198
                              • Montgomery, TX
                              Ok smart people I'm feeling really dumb here. rebuilt the master with a new kit. Used red rubber grease on everything. piston goes in and out no issue. Add dot 3 brake fluid and attempt bench bleed. Piston stops unless you maintain the pressure on the port. Am I missing something?
                              81 LH in process
                              09 vstar 1300
                              only allowed 2
                                • 2020
                                Seems backward.....you're saying if you put your finger over the hole for the banjo blot, then the piston will move, but if you take your finger off the opening the piston will not move?
