Aux Terminal Block
  • Mjpcarbon
    • Jul 2024
    • 52
    Aux Terminal Block
    So what is this AUX Fuse block typically used for ? I was thinking of getting a heated vest for the cooler days and was wondering if this would be a good source to power it ?
    • 8962
    I would get rid of it and use a slot in the new upgraded ATC style fuse block for that.
    What I really mean is keep the aux. block but bypass the glass fuse and wire it into the new style block.
    The problem with a heated vest is a great drain on the charging system although,
    ​​​​​​ others I'm sure have done it.
      https://www.ebay.com/itm/143445206467
ID:	881531 Click image for larger version
