carb gasket holes
  • edgo
    • Jul 2005
    • 138
    • Tampa FL
    carb gasket holes
    I punch out all of the pre-cut holes on the gasket in my K&L carb rebuild kit. Now that the carbs are installed the bike is doing the runaway idle thing like it has an air leak. On the edge of the carb body there is an open hole facing down, on the left rear of the edge where the gasket is. Is this hole supposed to be open or should the gasket cover it? I'm thinking this is my air leak and the source of my fast idle.
    Thanks,
    Ed
    79 XS1100SF
    78 YZ400E
    81 SR500
    79 RM250
    77 YZ400D
    05 RM250
    78 CR 250 Husky w/TT500 motor
    The hole in the red box does not go anywhere, either into the carb body or to a corresponding hole in the float bowl. It should make no difference whether or not the gasket had a hole there.
    OTOH, the hole in the blue box does go somewhere, both in the carb body and in the float bowl. I believe it is an atmospheric vent for the hole that receives the brass tube of the enricher circuit.
    I'm guessing the source of your fast idle might be a simple as needing to adjust the idle speed screw between carbs #2 and #3. If you did a bread tie sync, this is a sure thing as this sync method leaves the butterflies set way too wide open.
    • Winterhawk
      • Jun 2004
      • 684
      • Missouri
      I've punched out all the holes in K@L's gaskets all the time and haven't had anything weird happen. Maybe your clamp is touching the linkage or not enough slack? Carb sync?
      Let us know what when you find out.
      • edgo
        • Jul 2005
        • 138
        • Tampa FL
        The linkage is free and and snaps back when the bike isn't running. I'll turn back the big knob and see what happens. The bike idles fine when you first start it up. Then when you blip the throttle the engines revs up to 5K and won't go down.
        Ed
        79 XS1100SF
        78 YZ400E
        81 SR500
        79 RM250
        77 YZ400D
        05 RM250
        • RiskyBusiness
          • Mar 2003
          • 174
          • Richmond, Virginia, USA
          I had the same symptom and it was caused by the carbs being slightly out of sync. I don't understand conceptually why sync would cause this, but resyncing fixed my idle stick.
          1979 XS1100 Special with 81 carbs
          • Pat Kelly
            • 3046
            • Golden Valley, AZ
            The easiest way to find where air passages go (or if they're blocked) is to blow smoke through them. A straw helps.
            I learned this from rebuilding on automatic transmissions. Valve bodies are a nightmare maze of passages.
            Pat Kelly
            <p-lkelly@sbcglobal.net>
            1978 XS1100E (The Force)
            1980 XS1100LG (The Dark Side)
            1999 Suburban (The Ship)
            1994 Dodge Spirit (Son #1)
            1968 F100 (Valentine)
            • Bud Manley
              • May 2003
              • 414
              • Clayton, Michigan
              Ed
              I did the bread tie synch and had a similer problem. didn't read that I needed to almost close the big knob for proper idle.
              Also while trying to pull the carbs I bent the throttle cable holder deally. when I hit the throttle the Cable holder got stuck on the rubber carb boot and wouldn't release.
              79 XS1100F "JINGUS"
              07 V-star 1100
              Do you want it done right or do you want me to do it?
              • edgo
                • Jul 2005
                • 138
                • Tampa FL
                I backed the big knob down so it idles at 1K. It runs real strong off the bottom, not real clean but good in the middle and it screams on top. I think with some new plug wires it will be in good shape.
                Thanks for the help.
                Ed
                79 XS1100SF
                78 YZ400E
                81 SR500
                79 RM250
                77 YZ400D
                05 RM250
