half moons
  • DeanR
    • Jan 2005
    • 1484
    • Finger Lakes NY
    half moons
    Trying to seal up a leaky half moon plug. I have a new one to put in and I have black RTV and Yamalube 4. Is one any better than the other and any tips on getting this sealed up right the first time? I've had good luck putting no sealer at all on the valve cover gasket. The only problem has been at that darn half moon. Thanks.
    80 SG
    81 SH in parts
    99 ST1100
    91 ST1100
    YamaLube or YamaBond? There is a big difference. YamaBond 4 will work good, probably better than 'Sillycone'. It works great sealing up the crankcase joints..
    • DeanR
      • Jan 2005
      • 1484
      • Finger Lakes NY
      sorry, mispoke, I did mean Yamabond.
      80 SG
      81 SH in parts
      99 ST1100
      91 ST1100
      • pathfinder
        XStremely XSive(Deceased)
        • Apr 2004
        • 483
        • Houston, TX
        Yamabond # 4 works the best. IMHO
        78XS11E
        • Winterhawk
          • Jun 2004
          • 684
          • Missouri
          According to Bob Jones He says that the half moons should be installed on a clean dry surface with absolutely no sealer of any kind. I've done it this way and it works great.
          • prometheus578
            XS-XJ Super Guru (RESIGNED)
            • Aug 2004
            • 4012
            • Olympia , Wa.
            Maybe with new ones. But with old, brittle ones, I'd clean the surfaces with Brakleen and then use your sealant of choice.
            • DeanR
              • Jan 2005
              • 1484
              • Finger Lakes NY
              Haven't yet closed it up. I did notice that the new half moon when inserted sits very slightly higher than the rim. Has anyone noticed this? Maybe as you tighten down the valve cover, it depresses the half moon enough for it to fit flush?
              80 SG
              81 SH in parts
              99 ST1100
              91 ST1100
              • prometheus578
                • Aug 2004
                • 4012
                • Olympia , Wa.
                Yes, it will then fit flush, and "pressure seal" the lower area. My concern with old ones is that they might have hardened and will not "pressure conform" to the half-moon shape of the head.
                • DeanR
                  • Jan 2005
                  • 1484
                  • Finger Lakes NY
                  No sealant at all with the new one?
                  80 SG
                  81 SH in parts
                  99 ST1100
                  91 ST1100
                  • prometheus578
                    • Aug 2004
                    • 4012
                    • Olympia , Wa.
                    I seal everything!
                    That way, if it leaks, I can't yell at myself... "You idiot... why didn't you use sealant?"
                    (Of course, if something leaks with sealant, then I just yell, "You idiot!)
                    • Winterhawk
                      • Jun 2004
                      • 684
                      • Missouri
                      You just have to trust me. No sealer on the new ones.
