1981 Yamaha XS1100 Special
  • MarchHare
    • Oct 2023
    • 1
    Hello, Sometimes, we share our male porn collections with other gay friends, and it makes for a fun and exciting movie night with lots of laughter and conversations.
    👬 Find hot HD videos of the best gay porn stars on Gay Porn. Satisfy any desire with a large selection of hardcore and softcore clips.
    Free gay porn with the best XXX movies featuring hand-picked top male pornstars. Watch 'em get down and dirty representing every category from toned twinks to muscular hunks. 🌶️ - FreeGayPorn.club
    • 300
    Hi MarchHare,,,,sounds like the common second gear xs1100 worn gear issue. Do a search for second gear fix and read up a bit. Maybe try the clutch adjustment at both ends of the clutch cable, down by the clutch and also at the top at the handle,,the procedure is in the manual or in the search area,,,, ,,,also try new 20/ 50 oil,,,,if your oil is mixed with gas, common with carbs leaking into the oil,,,, that causes the oil to thin out, that definately affects gear shifting. Worst case, its fixable by the second gear bevel grind fix if needed, but that requires some time. Keep us informed,,,the xs shifts like a tank, so hard shifts are common and oil, adjustment can smooth it out somewhat....Mike in San DIego and Pa.
      It's good news that it doesn't slip. It points to shift linkage or shift fork.
      I'd check the shift linkage first. You can remove the cover behind the shift lever and watch the linkage as you shift up and down through the gears. Also check the dots line up properly as shown in the service manual. Examine the star wheel and associated parts.
        • 8083
        Screwed? Only if you think you are.
