If I put my voltmeter to one of the whites coming off of the XJ alternator while running, what should I see?
White wire voltage?
White wire voltage?
"Galaxy" 1982 XJ1100J, 1983 XV handlebars, new fusebox, homemade SS wind screen and SS muffler heat shields, homemade grab bar extension and luggage rack. XS750 140 mph speedo, '81 Venture oil cooler, V-Max ACCT, Yahman YICS Eliminator, 1st and 2nd gear Dremel fix.Tags: None -
I have 4.5 AC volts.between the white to the tach and the white going to the computer monitor"Galaxy" 1982 XJ1100J, 1983 XV handlebars, new fusebox, homemade SS wind screen and SS muffler heat shields, homemade grab bar extension and luggage rack. XS750 140 mph speedo, '81 Venture oil cooler, V-Max ACCT, Yahman YICS Eliminator, 1st and 2nd gear Dremel fix.Comment
Ok, what seems to be the problem with the bike, not charging properly?
May want to check the voltage at the triple white wire connector at the voltage regulator. The XJ alternator is a brush style where the brushes can wear out.Last edited by bikerphil; 09-30-2023, 09:06 PM.2H7 (79) owned since '89
☮Comment
Found it. In my search for issues my cheap Wal Mart battery was causing, I had disconnected the whites connector and reconnected it with one of the male blades doubling up on another. Too many times I am my own worst enemy, and I need better connectors.
1 Photo"Galaxy" 1982 XJ1100J, 1983 XV handlebars, new fusebox, homemade SS wind screen and SS muffler heat shields, homemade grab bar extension and luggage rack. XS750 140 mph speedo, '81 Venture oil cooler, V-Max ACCT, Yahman YICS Eliminator, 1st and 2nd gear Dremel fix.Comment
You hate when that sort of thing happens! Then again if it doesn't cause any other damage it's a cheap learning experience.1980 XS1100G
Intelligent people discuss ideas, average people discuss events, petty people discuss other people.Comment
With all due respect, how on earth were you able to plug that connector together like that and not notice something was wrong?2H7 (79) owned since '89
☮Comment
Cheap aftermarket connectors. The blades are wobbly in there and didn't put up a fight."Galaxy" 1982 XJ1100J, 1983 XV handlebars, new fusebox, homemade SS wind screen and SS muffler heat shields, homemade grab bar extension and luggage rack. XS750 140 mph speedo, '81 Venture oil cooler, V-Max ACCT, Yahman YICS Eliminator, 1st and 2nd gear Dremel fix.Comment
Yep, I see. Another case of inferior made in China copy crap.
I bought the good ones before from Tony at Oregon Vintage MC parts, maybe he still has them.
☮Comment
