NOS ignition pickup coil - how bad do you want it?
  • Ccitis
    replied
    BTW, the correct gap of the P/U coils is .027" (.7 mm).
    If there is paint on the screw head and they're still on the back plate, the gap is set.
    Thank you!
    Leave a comment:
  • speedlimit85
    replied
    Leave a comment:
  • Ccitis
    replied
    Sorry to hijack, but does anyone know the proper gap from the sensor to the part that spins?
    Leave a comment:
  • Mathh
    replied
    Hi LAB, I'm not sure if that unit would survive the environment of heat and cold more that a few years. It has never been tested because there is no documentation other than a sales ad. Maybe it would last. Maybe it wouldn't. The original equipment has lasted up to 45 years. I would spend the money on the real deal.
    If I remember correctly some of the Australian members use this Sachse unit as do several German members. All without problems and i know it is hot where some of them live. I always found Sachs expensive but comparing it to that NOS part on Ebay I think I changed my mind
    Leave a comment:
    replied
    Originally posted by ellieenby
    You saved me so many hours of research by posting this link, my project bike had this installed into it and was ripping my hair out looking for where the ignition pick up coils were on my bike. Tysm.
    I've never used it but have kept it in mind just in case. It was actually another member here asking if anyone tried it out that led me to it.
    Leave a comment:
  • ellieenby
    replied
    Originally posted by LAB3
    For the money I'd be tempted to go with this.
    https://www.elektronik-sachse.de/sho...ha-xs1100.html
    Leave a comment:
    replied
    Yep, I used a gauge to double check.
    Leave a comment:
    replied
    Thank you Phil.
    Leave a comment:
    replied
    The thread pitch on those is 1.0
    Leave a comment:
    replied
    Here is a picture of a 1980 anti-tamper screw. It looks like an M6. Part # 3H5-81674-00-00.
    Leave a comment:
    replied
    I found that a 78 has a conventional pan head screw (they must have changed due to dealership warranty issues of customer tampering) part # 97885-06030-00. The middle of the part number states it's a M6 x 30mm length. I'm guessing the thread is 1.25mm.
    Every now and then someone asks what size a particular bolt is. Just thought it would be helpful to post this from another site. FYI, you can get the part# from most Yamaha dealer websites or here. "How to get sizes of bolts from the part numbers... The Yamaha microfiche shows the bolt size, you ...
    Leave a comment:
    replied
    Nice shoulder bolt. M8 X 1.25 threads?
    Leave a comment:
  • speedlimit85
    replied
ID:	874299 Click image for larger version
    Leave a comment:
    replied
    Thanks speedlimit85, that does not sound too bad.
    Leave a comment:
  • speedlimit85
    replied
    I used a drill to remove the heads of the tamper proof bolts and then removed them by hand.
    Leave a comment:
