Went to get the bike today to ride. Carbs cleaned this past winter thoroughly,float height set, bread tie sync to get it to where I can ride it. Turned on fuel and bike runs really nice but as soon as fuel is turned on #3 carb leaks-Rapped on float bowl but fuel steadily drips out of bowl. Would the float needles be the cause? Fuel drips after a bit steadily. I have new float needles to put in if need be.
float neeedles?
Originally posted by oldyam80sg View PostWent to get the bike today to ride. Carbs cleaned this past winter thoroughly,float height set, bread tie sync to get it to where I can ride it. Turned on fuel and bike runs really nice but as soon as fuel is turned on #3 carb leaks-Rapped on float bowl but fuel steadily drips out of bowl. Would the float needles be the cause? Fuel drips after a bit steadily. I have new float needles to put in if need be.
Thanks for the reply Tony! I bought new float needles a while ago. Going to take the carbs off and replace it. I was amazed how well the bike sounded after going through the carbs-no carb popping at all. Was able to walk away and make a phone call while the bike was running. Fuel was shut off to carbs 3 and 4.1980 XS1100 SG
Originally posted by oldyam80sg View PostThanks for the reply Tony! I bought new float needles a while ago. Going to take the carbs off and replace it. I was amazed how well the bike sounded after going through the carbs-no carb popping at all. Was able to walk away and make a phone call while the bike was running. Fuel was shut off to carbs 3 and 4.
Tony-could it be the washer in the float seat? T I dont know why it would be a steady stream of fuel.1980 XS1100 SG
The '80 and later carbs have an o-ring on the float needle seat and screw and bracket to hold them in. They are sometimes hard to remove on account of corrosion. Once removed the bores can be polished so the new o-ring seals well. Also polish the needle seats.1980 XS1100G "Dolly G" Full Dresser (with a coat of many colors )
What do I polish it with Schming? I have replacement O rings as well if I need to replace it.1980 XS1100 SG
Originally posted by oldyam80sg View PostWhat do I polish it with Schming? I have replacement O rings as well if I need to replace it.2 - 80 LGs bought one new
Originally posted by oldyam80sg View PostWhat do I polish it with Schming? I have replacement O rings as well if I need to replace it.1980 XS1100G "Dolly G" Full Dresser (with a coat of many colors )
So I took off the carbs today and took it so where I can work on them-Moms garage.I removed float bowl # 3 and took out the float needle. It didn't look too bad but replaced it with a new one. The float seat was VERY dirty. It took 3 q tips and was almost black upon initial cleaning. I doint know how I skipped this in my winter cleaning. I put everything back together and after dinner, put the carbs back on the bike. Will start it up tomorrow-weather permitting.Last edited by oldyam80sg; 05-07-2023, 06:13 PM.1980 XS1100 SG
Most have been the dirty float seat. Started the bike today and no leaks. Ran for a while before I shut off the bike.1980 XS1100 SG
I start the bike daily-no issues. I will ride it to my Moms house this weekend. I can't believe how good this runs.1980 XS1100 SG
