carbs
    • 2074
    carbs
    Can get some ZRX carbs for my 80 SG. Who is running them on here? Any issues?
    • 2074
    Messaged Bonz and he gave me some advice. Maybe going with different carb mod but NO -my stock XS 1100 SG carbs are not for sale.
    • red bandit
      • 957
      • central michigan
      I've run them on & off. Off right now. No reason. You have to come up with a way to connect the throttle cable. They are a little shorter than the xs carbs so taking them on & off is a little easier. There is no #2 port for the vacuum advance but one could be added fairly easy. I still got the same mpg. Nothing against them. They are just a newer model but they are getting old too. Seems like I've heard that before. lol.
      79 SF parts bike.
        • 2074
        Having a ZRX1100 I kind of figured out that there are mods needed for the choke and throttle cables to work on the XS1100. Not plug and play as it would seem. My XS1100 and ZRX 1100 are both sitting covered in a locked storage unit maybe 1/2 mile from my apartment that I pass by everyday. Parts are not cheap as I looked on partszilla alone and1 single float is $50.00. Then you must play with jetting and the vacuum advance. If no gain in mpg or power I wonder how much more better these would work.
        • garethagain
          • Oct 2021
          • 4
          I had them on my 79SF. Played around with all sorts of workarounds to make the vacuum advance work. Throttle cable involved some shortening of the outer sleeve and crimping on a pull stud. I didn't pursue changing to a push-pull setup. I was 20 years younger then and had lots of enthusiasm and energy for mods that ultimately provided very little payoff in real performance. Lots of messing around with bigger jets etc. When I got my current 79 Standard, I used all that early experience to clean and tune the stock carbs to be the best they could be. I'm still on the stock mufflers although they needed some major welding and patching recently to handle the rust and rot. Bike runs great when its tuned as stock: timing and valves set, compression in order , strong battery, clean electrical connections. I did install Accel coils and lose the resistor. Otherwise, bone stock. I've stopped second-guessing the original engineering in my other bikes too. Getting older, I guess. makes owning a survivor bike more appealing. Matches the rider better.
            • 3271
            Have you searched XS11.com? Here's another thread for you... vacuum advance in ZRX carbs.
            ZRX1200
            Seca 750
            • e30 gangsta
              • Mar 2016
              • 142
              • Lone tree, Colorado
              I have a set of zrx carbs that I never ended up using. comes complete with no jets if anyone is interested. No jets because the stock zrx carbs jets have to be changed anyways.
              80 XS1110 SG, RD400
