Suzuki Carb Parts for Our XS1100 Carbs
    • 8061
    The link is to XS650.com. The thread is relevant to XS1100 and an opportunity to save some money on parts.
    A couple of these have been mentioned before, the butterfly shaft seals and the brass floats for the 1980 BS34s ..... ..... but I've discovered some...
    • 8891
    I believe those throttle shaft seals fit our late type carbs. The early type uses a different/larger/way more expensive seal. I didn't see the throttle plate screws listed there. Bummer
      • 8061
      I think the butterfly shaft seals are all the same. I do know that the same ones fit my XS1100 and my XS650 and my XS650 with BS38 carburetors.
      Brass floats are available at Summit Racing.
      Mikuni VM24/171 Mikuni Floats | Summit Racing
        • 8891
        The early and late have different part #s and the late ones are smaller. I know this because recently I changed them on 2 banks of early and 1 bank of late.
          • 2138
          Thanks Marty!
          I have used the Suzuki BSS in older (brass float) and newer (plastic float) XS11 carbs.
