Carb rebuild kit - what is this part?
  • Brianc
    • Aug 2022
    • 4
    First post! What is this small disc for? This is from Scrambler’s rebuild kit of a 1980 xs.
    • 8736
    It's a cap for the tower the idle mixture screw sits down in. They came capped from the factory to discourage any tampering (EPA) with the mixture screws.
      • 7692
      You can use a dremel tool to cut a slice in the carb so without the cap you don't have water, oil, etc. collecting on top of the adjustment screw.
      • Brianc
        • Aug 2022
        • 4
        Thank you both.
        • Tim
          • Sep 2022
          • 6
          • West Texas
          The earlier XVS13 (4 cyl yam cruisers) had plugs about that size you had to tap out and back in to replace the float needle seat like 1996 I'm thinking
