Choke lever tension spring
  • MAX ACUFF
    • Jul 2022
    • 2
    Does anyone know which way the spring tension on the choke lever hinge spring is set ? Should the spring tension be pulling the lever arm IN, toward the carbs, or OUT away from the carbs ? I disassembled mine and now trying to re-assemble.
  • red bandit
    • 970
    • central michigan
    It should pull the lever in towards the carbs, the choke off position.
    79 SF parts bike.
    • MAX ACUFF
      • Jul 2022
      • 2
      Thanks, darn spring is tough.
