Need charging advice
  • Steverk
    • Oct 2020
    • 35
    • Holland, Michigan
    been rebuilding my bike over the last couple of winters. I recently fired it up for the fist time and noticed the tach was not working. This led to some diagnostic testing that has led me to believe the alternator may be bad. Hear is what I have discovered;
    field coil resistance= 3.9-4.0 ohm
    stator = .6 Ohms across the 3 whites wire.
    Voltage at green wire from voltage regulator (new EBay reg) = .1 volts with key on, BUT drops to 0 volts once bike is running.
    So my question is, is the above alternator resistance measurement enough to indicate a bad alternator? Am I missing something else?
    battery is new AGM and voltage is good.
    any help would be appreciated.
    Steve K
    1980 xs11 special
    1979 xs400
    1989 Sportster
    2016 KLR
    2016 Africa Twin
    1965 Chevelle
    1970 Wife
    • 8894
    Yes, inspect the alternator wiring harness connector for melting or corrosion. It is located behind the fuse box mounting plate which is held on by 3 screws. Common problem on these bikes.
    • Steverk
      • Oct 2020
      • 35
      • Holland, Michigan
      Connectors are in excellent shape and I have cleaned all of them thoroughly. Both the resistance readings are out of range per the spec in the manual, but I don't know if that is enough to call the alternator or field coils 'bad'. I would have expected some charging, even if it was weak- nada. Additionally, I also tested all of the alternator wires for dead shorts- negative. I also tested the harness wires for continuity to check for a hidden break inside the insulation- negative.
      Steve K
      1980 xs11 special
      1979 xs400
      1989 Sportster
      2016 KLR
      2016 Africa Twin
      1965 Chevelle
      1970 Wife
        • 8894
        Well, if the alternator is out of spec it may be the problem. If the new regulator from ebay you installed is a cheap China knockoff that may also be the problem. There is a test you can do to see if the alternator is actually putting out. With the bike running, take a jumper lead from ground and add it to the green wire of the field coil harness and see if it starts charging. This would temporarily bypass the regulator and you should see 15V output from the alternator if it is working.
        • Steverk
          • Oct 2020
          • 35
          • Holland, Michigan
          thanks I'll give the jumper wire test a shot. When doing this test, should the harness to the regulator be unplugged? Yes, the regulator is a china cheapo.
          Steve K
          1980 xs11 special
          1979 xs400
          1989 Sportster
          2016 KLR
          2016 Africa Twin
          1965 Chevelle
          1970 Wife
            • 8894
            Leave the field coil plugged in and just tap in to the wire end of the plug with the ground jumper. Yep, I've had no luck with the Cheapo China regulators, every one I've tried was bad.
            • Steverk
              • Oct 2020
              • 35
              • Holland, Michigan
              Roger that. Thanks.
              Steve K
              1980 xs11 special
              1979 xs400
              1989 Sportster
              2016 KLR
              2016 Africa Twin
              1965 Chevelle
              1970 Wife
              • Steverk
                • Oct 2020
                • 35
                • Holland, Michigan
                Went through everything again last night with a buddy, and it appears that the stator is the likely culprit. Thanks for the advice and if anyone has a working stator, I’d be interested. I also posted in the parts wanted. I have a lot of spare parts for an ‘80 include a couple of parts engines.
                Steve K
                1980 xs11 special
                1979 xs400
                1989 Sportster
                2016 KLR
                2016 Africa Twin
                1965 Chevelle
                1970 Wife
