Stutter, Cam Chain Slip, Bent Valves
  • Banshee's Veil
    • 104
    This is what basically caused my problems. The slides would rattle here and not drop back down to idle after letting go of slight throttle, as the springs didn't have enough tension to overcome the engine vaccuum. I lubed the slides with silicone and added another spring. I'm pretty sure this is fix the issue. I have to wait for a new valve cover gasket however.
