Need a couple parts for XS1100H
  • Steve Rowen
    • 1
    • Denver, Co
    Hi To All,
    I need the stock lefthand exhaust shield below the left footpeg. I'm also trying to figure out how difficult it would be to come by a clean righthand rear factory midnight blue storage case, or if I should try to repair mine, as it has a vertical crack that's barely noticable. Thanx in advance.
    Steve
    Parts for XS 1100H
    Hi there Steve! Gonna be almost impossible to find another hard case......seen one set for the Venturer on ebay awhile back....with wrap-around and all. Don't know what it went for, but was at almost $500 and bidding hadn't ended. Anyway, you should have a place there that'll do a good job plastic-welding it for you, as there is a place here in GrandJunction that does nice work very reasonable, and worth having done. Most do it in black, so won't be very noticeable on the color. The correct color name is Indigo Blue! At worst, sand down case,use primer for plastics, and re-paint, then re-stripe.....and that reflective striping is available at most automotive paint suppliers. let me know if your having any trouble with all that.....finding a source, etc.
