Long term implications of early adoption of technology
  • tommystinson
    • Aug 2003
    • 425
    • Albany, NY
    It's been over a decade since I sold my XS to my neighbor and good friend. I sold it for far, far less than what I had into it, and even less than blue book or what have you. I sold a strong running bike, with functional improvements. Some of those improvements were hard to accomplish due to the "high technology" of the XS. It works against those trying to make a running motorcycle. I refer primarily to the ignition system.
    In 1978, the XS debuted with a fully electronic ignition. Vacuum advance. Slick.
    Rivals had points and capacitors, which, frankly, suck. Mechanical advance. Suck.
    But there were excellent bikes that had ****ty ancient ignition systems. The Kawasaki 1000, etc.
    Over the years, multiple manufacturers have stepped up to the plate to provide a replacement for points and capacitors on these bikes. There's a market because the original systems sucked.
    So, in 2021, the aftermarket solution is... a transistor based ignition module, a timing plate and Hall-effect "sensors".
    The same technology the XS had in 1978.
    But, since the XS already had this stuff and there aren't many XS's, nobody made an aftermarket kit. (?)
    I was lucky to find NOS pickups from a dealer 170 miles away. I bought a couple extra ignition boxes to work with. Tested transistor outputs then replaced every single capacitor in the box.
    Had a big fat spark at the right time through Accel coils.
    I realized then if I had a KZ1000, I could have bought a kit off the shelf, swapped it, and be good-to-go.
    So, cutting edge technology sold to a limited market has limited utility, and may actually hurt you in the long run.
    I have 300 LaserDiscs that I've replaced with Blu-Ray. I can't bring myself to throw them away. Go figure.
    Anyway...
    2010 Kawasaki Z1000
    • 7785
    Digital ignition system for Yamaha XS1100, replacement for the original electronic ignition and advance unit. The vacuum advance won't be used any longer. Most models have a 15 mm shaft diameter. The 2H7 and 2H9 models have a 14 mm shaft...
    • tommystinson
      • Aug 2003
      • 425
      • Albany, NY
      Touché! When did that get released? And beyond that, how did you come across it?! It certainly didn't exist fifteen years ago...
      2010 Kawasaki Z1000
        • 7785
        We've been here a long time. It has com up on XS11.com.
