alrighty, just got this '78 standard last weekend.......runs good with the exception of rough idle (#1 & #2 cylinders kick in & out) and once you get her to idle she's choppy. Also, if you try to give her gas she falls flat out trying to die
I pulled the carb bank off, and am about to clean them and reset the floats......only 1 problem: i don't have a manual
Does anybody know what the float height is supposed to be?
Also, not sure if this matters much, but the previous owner took the stock '78 carbs and swapped them for a set off of an '80......does that make any differences?
Thanx for any and all advice.....would love to get this thing running good this weekend if possible
