Oil pressure light question…
  • ERM83
    • Apr 2016
    • 314
    • Lehigh Valley, PA
    Can I wire the oil light externally?? I know that the fuel light (80’ special, by the way) cannot work with most aftermarket speedos, being that it goes through a step-down regulator, from what I’ve read here. After looking at the wiring schematic, does the oil pressure light also go through that as well?? Definitely need that light!
    My dumba$$ stripped the oil drain plug, so I’m waiting on my “new” oil pan to get here. I’m so pissed at myself for stripping that…but I figure it’s a good chance to clean the pump screen.
    80' XS1100 SG "Dottie"
    79' SF carbs
    MAC 4-1
    K&N Pods
    Accel 3.0 coils
    Tarozzi fork brace
    TC fusebox
    Picture update soon
    http://i53.photobucket.com/albums/g4...psej6wqu9l.jpg
    79' XS1100 SF (parts, will be reborn)
    http://i53.photobucket.com/albums/g4...snfgpozqn.jpeg
  • ERM83
    • Apr 2016
    • 314
    • Lehigh Valley, PA
    Aka, can I wire a separate light for the oil pressure sensor outside of my new speedo / tach without frying anything??
    79' SF carbs
    MAC 4-1
    K&N Pods
    Accel 3.0 coils
    Tarozzi fork brace
    TC fusebox
    Picture update soon
      • 8690
      Yes you can, attach 12V+ to one side of the bulb and then attach the wire from the sensor to the other side. The oil pressure sensor is just a ground switch (normally closed) which completes the circuit when there is no pressure (light is on) and breaks the circuit when there is oil pressure (light is off).
      Edit: After studying the wiring schematic of the SG, you should be able to use the blk/red wire and the brown wire in the harness plug in the headlight bucket to run to your new bulb.
      • ERM83
        • Apr 2016
        • 314
        • Lehigh Valley, PA
        Thanks Phil, much appreciated!!
        79' SF carbs
        MAC 4-1
        K&N Pods
        Accel 3.0 coils
        Tarozzi fork brace
        TC fusebox
        Picture update soon
          • 8690
          You bet, hope it works out for you.
          • ERM83
            • Apr 2016
            • 314
            • Lehigh Valley, PA
            Well, just put the light in, and…whole buncha nope. I don’t understand at all…I used the correct connections, and even tried the old light…that doesn’t work either. At a loss!!
            79' SF carbs
            MAC 4-1
            K&N Pods
            Accel 3.0 coils
            Tarozzi fork brace
            TC fusebox
            Picture update soon
              • 8690
              Ok, first I would check the sending unit. Unhook the wire and take your ohm meter and check the sensor terminal one side and ground the other. The reading should be infinity (circuit complete). With the bike running and oil pressure is present, there should be no reading (open circuit). If this checks out, check continuity of the sensor wire, one lead down at the sensor blk/red wire and one end up top at headlight bucket blk/red wire.
              • ERM83
                • Apr 2016
                • 314
                • Lehigh Valley, PA
                DUDE…the wire from the actual unit was unplugged!!! How that happened, I have NO IDEA. I haven’t even messed with that side of the circuit since I’ve had it. The wiring behind the right cover is a NIGHTMARE (thanks to the PO), and I couldn’t figure out where it even plugged in!! I found it, and Phil, thanks again for the advice!
                I’m half tempted to just re-wire the whole thing from scratch. Probably going to wait for the rebuild / having a bigger space to work on it, but it really does need some cleaning up. I HAVE TO have another bike to ride while I rebuild it, though…I’ll lose my mind if I can’t ride. 100% serious. There’s a 78’ for sale around me for a decent price, and no one’s biting…
                79' SF carbs
                MAC 4-1
                K&N Pods
                Accel 3.0 coils
                Tarozzi fork brace
                TC fusebox
                Picture update soon
                  • 8690
                  Yep, I forgot about that plug behind the RS cover, glad you found it. Let us know when you get it working.
                  • ERM83
                    • Apr 2016
                    • 314
                    • Lehigh Valley, PA
                    Forgot to check back in - it’s working perfectly!! Easy install!
                    79' SF carbs
                    MAC 4-1
                    K&N Pods
                    Accel 3.0 coils
                    Tarozzi fork brace
                    TC fusebox
                    Picture update soon
                      • 8690
                      Sweeeeeet.
