79 xs11 standard question
  • Grimace
    • Sep 2005
    • 77
    • Edmond, OK
    Will the headlight only come on with the bike running? I was looking at the wiring diagram, and it looks like the headlight relay only will fire if you have voltage coming from the alternator. Is this correct? I am in the process of converting this standard from a vetter fairing to no fairing. I am trying to get the headlight working, but I have no power at the green wire, or yellow wire at the headlight. The fuses are good. The also seems to be no visible damage to the wiring or plugs. I checked all the connections for corrosion, and cleaned them as needed. Thanks for any help,
    J
    That is correct - the headlight doesn't come on immediately.
      Grimace
      I am having the same problem with my bike. Check the Red wire /yellow tracer for power into the headlight relay, and then check the blue/black for power out of the relay. If you have power on the blue/black, then the relay is good, and the problem is downstream, possibly at the Reserve Lighting Unit. You can bypass the relay by running a jumper wire from the red/yellow to the blue/black wires. If the ciucuit and the RLU are good the light will come on.
      • valhallan
        • 66
        • Churchville, Maryland
        its helpful
        if you have a low, weak battery, not having the headlamp on when you go to start makes a big difference sometimes, so its a nice feature. When your haveing bike problems though, it can be a little annoying trying to convince the local no-it-all the battery is fine even though the headlamp isn't on (i was THAT close to strangling the idiot)
        • Grimace
          • Sep 2005
          • 77
          • Edmond, OK
          Thanks guys, that confirms what I thought. I will have to wait for the clear on the tank to set before I can finish sand and buff it. Then I can get it started.
          • andreashweiss
            • 951
            I have 4 reserve lighting units in my parts pile. In case it is the problem and you need one. andreashweiss@yahoo.com
            • Grimace
              • Sep 2005
              • 77
              • Edmond, OK
              You might have one sold. Thanks for the offer
