Gas Tank Lid
  • CLTBLUESMAN
    • Aug 2013
    • 38
    • Mooresville, NC
    Gas Tank Lid
    Ok, I got the key for the bike. I thought first place to try was the gas tank to see inside. I put the key in. It turns, however the tank will not open. I sprayed WD40 in the lock. It worked better, but just won’t open. I hear a click after I push down on it. I sprayed WD all around the lid. It just won’t unlatch. I don’t want to force it and break anything. It feels like it won’t retract far enough. It does work in the ignition.
    So, anyone have this issue?
    79 F
  • 2WheelFun
    • Aug 2020
    • 266
    • Pittsburgh PA
    You pushing down on the lid as you turn the key?
    1979 XS1100 Special
    1980 XS1100 Std parts bucket
    1987 ZL1000 Eliminator
      The seal may be stuck to the top of the tank. Push down, turn key, then lift. Pull up with key to help lift. If it does not want to open, you will need something to pry it up with the key turned.
      New tank seal from MikesXS will fit both Standard and specials.
      • CLTBLUESMAN
        • Aug 2013
        • 38
        • Mooresville, NC
        Yes I am. I tried it all kinds of ways. I hear this click after I push it down. It is as if something is not retracting all the way.
        79 F
          Bend a bit of 14GA sheet metal so you can slip it between the cap and the chrome trim. Push down and turn key, then slip it in and push towards the rear of the bike from the front center. That should release the catch if it's not working properly, though I do think it's the rubber gasket stuck to the top of the tank. You can use the sheet metal to pry up on the cap and see if it will free up.
          • CLTBLUESMAN
            • Aug 2013
            • 38
            • Mooresville, NC
            Success! I got it open. I very gently pried it open with a flat blade screwdriver. It popped. It was the latch on that pin.
            It looks great in there. Just a tiny bit of surface rust.
            79 F
