No spark 79 special
  • 2WheelFun
    • Aug 2020
    • 266
    • Pittsburgh PA
    No spark 79 special
    It ran when I parked it...lol.
    I had the front end off, all wires in the headlight bucket have homes except for a blue (double wire female bullet) and red (single wire female bullet). All fuses look good.
    Fixed second gear, adjusted valves and changed the spark plugs caps to NGK.
    fuel in the holes but no spark, I tried a stock plug cap and still no dice.
    Power is verified to the coil grey and orange leads.
    Any ideas?
    1979 XS1100 Special
    1980 XS1100 Std parts bucket
    1987 ZL1000 Eliminator
    • 2104
    Kill Switch / right control solder joints in good shape ?
    • Rosche
      • Aug 2020
      • 6
      • Hamburg, Germany
      Can't be killswitch,. It disconnects lead to coils.
      Rolf
        Check the ballast resistor, and then start from the top. Take off seat and tank, turn on ignition and check red/white wire at the resistor for 10.8+ Volts. I would also check the ground wires at the reg/rec to make sure they are good. Ohm check from the screw head to the battery ground, should be less than 2 Ohms. Print off a one page copy of the wire diagram and check off as you follow the wires with the VOM, checking for voltage or Ohm readings as needed.
        • Bax
          • 344
          • Merrimack, NH
          I posted this a few weeks ago. May help you as well.
          • 2WheelFun
            • Aug 2020
            • 266
            • Pittsburgh PA
ID:	863515 Click image for larger version
ID:	863514 Thanks for the help so far.
            12+v feeding the ballast resistor from female red/yellow trace bullet and 12+v coming out of the ballast.
            Where on the bike is the emergency shut off switch in the diagram?
            I found a red/yellow trace male bullet coming out of the harness just in front of the shock mount that doesn't seem have a mate. Any leads (haha, see what I did there) on where this would go?
            Maybe I have my wires crossed on the headlight bucket. The bullets I have connected for the 2 dk green female I plugged into the single blk male. The green/yellow trace plugged in to the green/white trace. I downloaded the diagram but it's not helping me much on my phone. I need to go to the office and print an 11
            1979 XS1100 Special
            • Bax
              • 344
              • Merrimack, NH
              Tip switch in the pic. If you have 12V at ballast resistor, problem is not in the headlight bucket bundle.
              • Bax
                • 344
                • Merrimack, NH
                The missing lead you ask about. Connects to the load side lug on the starter solenoid. That bypasses the ballast resistor on startup to provide extra spark energy during starting.
                ---Bax
                • Bax
                  • 344
                  • Merrimack, NH
                  ID'd in your pic
                  • 2WheelFun
                    • Aug 2020
                    • 266
                    • Pittsburgh PA
                    Thank you, thank you, thank you.
                    I have not had that one hooked up last year but it ran. Weird
                    I now have spark and she runs!
                    I found the black box emergency stop what the heck does that black box do?
                    In the headlight bucket, it looks normal to me Center right signal wire to double dk green
                    center left signal wire to double brown
                    My signals were hooked up backwards but left to brown is correct
                    Front brake switch brown to a brown (but the female harness connection has room for one more wire)
                    Blue wire female jumper from gauge loom to main harness has no male counterpart.
                    Red wire female from main harness has no counterpart
                    1979 XS1100 Special
                    • Bax
                      • 344
                      • Merrimack, NH
                      It's a tip over switch. Kills the ignition if the bike goes down. There's a test procedure, with a good explanation of function in the service manual.
                      ---Bax
                      Good to know it's back to running again.
                      • 2WheelFun
                        • Aug 2020
                        • 266
                        • Pittsburgh PA
                        Nice to hear the oem exhaust note for the first time! Engine sounds happier with the valve adjustment and tensioner reset.
                        Luckily it was sitting bare with the old riding mower tank ready for the carb sync which was supposed to be done yesterday. Today is a total washout with rain. Hopefully later this week I can sync the carbs, go over all the pressures and see how the trans work played out.
                        Thanks again everyone for your help! Nice bunch on this site
                        1979 XS1100 Special
