Lock tab shims.
  • Bax
    • 344
    • Merrimack, NH
    Lock tab shims.
    Anyone have a resource for new lock tab shims for the front brake rotors? Mine are hurting.......
    ---Bax
    Mike's XS sells aftermarket locking tabs.
    $6.75 for a pack of three.
      Mike's XS has some.
      Lock Tab for Disc Brake Rotor (pk/3)
      $6.75
      IN STOCK
      Part
      29-6530
        Bax... I ordered these from Mikes XS and they are OK. Just watch your tightening sequence. If you are not careful they will break if you torque down too much. I did that with my first attempt because I was trying to get the bolt torqued so that the flats would align. Soon discovered that is not all that important.
        • Bax
          • 344
          • Merrimack, NH
          Thanks, I had seen the ones from Mikesxs earlier but noticed the figment listing omitted the XS1100 models for 80 up. Speed and Sport shows inventory for 80 up but none for 78 & 79 so I thought dimensions might have changed slightly with P/N revision.
            It doesn't matter. The folks at Mike's XS know very little to nothing about the XS1100. XS650 and XS1100 rotors and bolt spacing are the same.
            • Geezer
              • May 2003
              • 2985
              • Willamina, Oregon 97229
              I just tossed the ones on my bike and put in stainless allen head bolts. Torque them to spec and they won't back out. If you're really paranoid about it you can use a little Locktite.
              Hi, mt name is Tony and I'm addicted to stainless steel...
