Does anyone know the compatability with bondo, and powercoating? I will be stripping down, and doing a frame up restoration on Tank...and would like to clean the frame up. there is a lot of gusset work, and some sloppy welding done on the frame...OEM I am thinking, and just want to clean it up a little better. If ya got an idea on if it will work...post it, and I will love ya. I guess I could just call the body shop too, but that would be too easy, and I was here doing some searching anyways.
restoration question
most people put on beads of weld then grind them smooth
or you can use lead
but for powder coat it should be metalhttp://home.securespeed.us/~xswilly/
79F Parts
80G Parts
75 DT 400B enduro
i have just done my spare frame it was sand blasted or bead blasted,then it was painted not powder coated,when they were first made it looked like they only had a couple of coats of black paint,so now mine has about 6 coats of paint, to make the finish look as it was.
Bondo won't hold the powdercoating. Also remember that powdercoating is baked on, so anything that goes in the oven that can't handle an extended time at 350+ degrees won't come out of the oven. Any frame bushings, etc. need to be removed or they'll melt. Learned that the hard way restoring my old Hodaka. Forgot to press the swingarm bushings out before I sent the frame in for coating and when I got it back all I had were bushing sleeves in the hole!-------------------------------------
http://octaneonline.com
The powder coating process can get pretty hot. I'd worry about the lead sagging. I think 50/50 lead/tin solder would be a better idea.
