I finally got the screws out of the angle holding all four carbs together. They were a nightmare. I had to turn them a little, and soak the shanks in mouse milk. After I got them apart again, I found my problem with #1 and 2 not taking fuel. The "t" for the bowl vent was corroded shut. I guess this was from sitting outside for 7 years (p.o.). I took everything damageable (is that a word?) and set it aside, in a cup labeled for each carb. Then I soaked the bodies in chem-dip for about half an hour each. Then I hosed out each hole and orifice with carb cleaner, and got it ready to re-assemble. The "t" fittings for the vent and fuel were re-usable, so I just took a correct size drill bit and hand drilled the shtuff out. They cleaned up so I put them back together. I am in the process of the pre-sync right now. I just wanted to share my find on the "t" fittings in case someone was having trouble with fule starvation. My bowls will fill up if they sit for a while, but those carbs would run out of gas. I should have checked this first before I ordered new petcocks.
Justin
Justin
