It seems that the front brake calipers are seizing when the temperature drops below 60 degrees F. If I apply emergency repair procedure one (kick them), they will release until used again at which time they seize. As soon as they warm up, however, they seem to work normally.
I have already cleaned out the reservoir and holes as well as changing the brake fluid/bleeding the brakes. At this point I am in the dark. I hope some of you wise folk will be able to point me in the right direction.
Thanks,
LS
Thanks,
LS
