Choke/Enrichment Cable?
  • Choke/Enrichment Cable?
    As I walked around my new beast, shaking my head and muttering to myself, I noticed that I don't have a choke lever on the left controls. Did someone do a "midnight requisition" on the bike when she was sitting outside for months? or is it a manual lever on the leftside of the carbs that I can't figure out what it does.
    I jiggled it which did nothing, no battery so jiggling is OK
    Reason I am asking is there is a left control setup for sale on ebay and it doesn't have a choke lever either.
    Jack
    82 XJ100J Gone
    83 XJ750 Seca
    The xj has a choke cable on the left side handle bar switch pod. It is on the bottom of the switch assy, and it has a thumb lever. Are you needing one?
      Hey Jack,
      The choke lever just screws into the bottom of the left hand control set, it may have been removed or fell off? Look under the control set and see if there is a hole where the lever would bolt to!? On the carbs, that lever should be in between #2 and 3 carbs, not on the end of the bank!
      The Starter lever assembly is still available from BikeBandit, for a little over $7.00! The cable is $8.40.
        Sorry guys, this was for the XS not the XJ. My bad
        82 XJ100J Gone
        83 XJ750 Seca
          Okay Jack,
          The Xs has a choke lever on the left side of the carbs, but the handle part may have broken off as they often do! You'll want to spray some WD40 on that choke arm/rod that runs across to all four carbs, they get corroded and stiff, and cause much more resistance, and that's what adds to folks pulling the lever out too hard and bending and finally breaking the handle off of the lever. If you'll do a search in the Member's Forum for choke lever, you'll find a thread I posted about a repair replacement for one that is broken off!?
            Here's that thread:
            Choke lever thread
              I think I have used the wrong description of what I wanted to find out. On the XS1100 Standard, is there a choke control on the handlebars or do you use the lever on the carbs? I've looked at the fiche and don't see a bar mounting for the choke.
              Sorry for not being more accurate (its a curse)
              Jack
              82 XJ100J Gone
              83 XJ750 Seca
                I have a 79 F. Choke lever is on the left side o' the carbs. Nothing on the handlebars.
                  Great!!! Finally something I DON'T have to buy.
                  Thanks a lot.
                  Jack)
                  82 XJ100J Gone
                  83 XJ750 Seca
                    Okay Jack,
                    SNIP
                    Its tight as a drum but I am being very careful with it. Its all there so that's another plus but it doesn't move so when I get into the carbs I will see whats up.
                    Thanks T.C.
                    Jack
                    82 XJ100J Gone
                    83 XJ750 Seca
                      FWIW...
                      On the XJ, the choke cable connects to the carbs at #4 carb. As you sit on the bike, if you look (or reach down) you can see and/or manipulate the choke without using the cable.
                      Jerry Fields
                      '82 XJ 'Sojourn'
                      '06 Concours
                      My Galleries Page.
                      My Blog Page.
                        During a recent carb rebuild, noticed that the carb choke plunger was sticking in the carb bore on reassembly - even after a thorough cleaning with Berryman’s carb cleaner!
                        Solution: Liberal application of Sea Foam Deep Creep on all carb parts and carb body (exc. diaphram) during assembly process.
                        So for the sticking choke lever, be sure to check the choke plunger on each carb as well as the choke arm/rod.
                        Can't recommend Sea Foam Deep Creep enough, although I have not tried as an engine fogging oil yet.
                        http://www.seafoamsales.com/deepCreep.htm
                        • #13
                          Sounds a lot like Kroil
                          Jerry Fields
                          '82 XJ 'Sojourn'
                          '06 Concours
                          My Galleries Page.
                          My Blog Page.
