Can getting two vacuume diaphrams w/needles switched cause a rough idle?
Carbs back on, alittle rough.
It could if you have not resync'd the carbs after swapping the parts, or if you've inadvertently caused a vacuum leak somewhere.......Ken Talbot -
Your right, resynched today.
Just got it synchronized today, its running great.
I was just being paranoid, I knew I still had to synchronize and hoped that would do it.
I don't suppose getting the diaphrams switched would hurt anything as long as they were both set the same and not modified, right?'82 Xj1100j
"Ride for the Son"
JohnComment
