I put on new intake boots but my clamps bottom out, but I can still move them with my hand.That might be my problem with the carbs.Is this normal for the clamps. I sprayed them with starter fluid I got a hint of it reving up. They have got to be leaking with the clamps still loose.Do they stretch over time. Thanks
Intake boot clamps
Hey JohnFrench,
Those clamps are metal, but I guess they could possibly stretch, but I would think that perhaps the new intakes are just a bit smaller in outer diam/circumference than the OEM's ? Are the clamps truly "bottomed" out, the angled metal parts that hold the nut and bolt are touching each other?
New clamps are available from BikeBandit:
5: CLAMP,HOSE
(ISO) [CLAMP,HOSE] 352802-001 $4.90 ea
BTW, are you sure you have the right clamps on the right spot, that you don't have the Air Cleaner side clamps on the intake manifold location...they are different item numbers!?
T.C.T. C. Gresham
