speed vs rpm
  • #16
    I just realized that Mikes XS has a mini speedo that's calibrated for Yamahas with 19" front wheels, should be accurate on an 1100. The tach won't work since it's mechanical.
    Shiny side up,
    650 Mike
    XS1100SF "Rusty", runs great, 96k miles
    XS650SJ "The Black Bike", engine from XS650H with 750cc big bore kit, 30k miles
    Life is not a journey to the grave with the intention of arriving safely in one pretty and well preserved piece, but to skid in broadside, thoroughly used up, worn out and defiantly shouting, "WOW, what a ride !" - [URL="http://www.flyingsnail.com/Sprung/index.html"]Sprung[/URL]
    • #17
      Dean,
      On my LG I get
      Revs to mph
      5000 = 70
      6000 = 85
      7000 = 100
      Speed measured by GPS so should be pretty accurate, revs measured by unfaired eyeball on shaking rev counter
      Brian
      • #18
        That's right in line with what my instruments are telling me.
        Shiny side up,
        650 Mike
        • #19
          TC,
          The rpm is up not down - My 84 1100 sits at approx 3500 rpm at 100kph/60mph - this is my original bike with no work done to it at all. My 82 1100 (that has had work - from 2 owners previous) sits at approx 4500 rpm at 100kph/60mph.
          I haven't had them paced at all but after riding the same bike for 20 yrs+, the 82 "feels/sounds" different. Given the amount of time on my orig bike, when I ride the moded bike I find myself more often than not shifting from 5th gear into 5th gear because of the feel/sound.
          Do ya know what I mean?? Does that make sense??
          "ride to be visible but pretend you're invisible"
          84xj1100
          82xj1100
          • #20
            Just found this thread. I got Zilla put together today and ran it down hwy 51 about 30 miles.
            What you are saying is correlative with my '82 XJ1100.
            I'm seeing about 4400 to 4500 rpm for 60 mph and at 6200 rpm it's registering 80 mph on the nose.
            For some reason that's not what I thought it did on the trips I took last year I thought it was spinning 4000 @ 60 mph.
            I'll verify tommorrow with a GPS. I'll also post pics of the "New and Improved Zilla"
            L8R
            • #21
              Was just riding my SF and it shows 4,000 @ an indicated 60. I'm not sure about that tach but the speedo seems pretty accurate at highway speeds. I plan to clean up the wires and terminals going into the tach and see what I get then because my tach is somewhat erratic when changing engine speed.
              Shiny side up,
              650 Mike
              • #22
                On our return from So. Indiana last summer on the 4-lane we sat mostly at right at 80MPH indicated on the speedo and that was 5,000 RPM on my 78. I recall somewhere seeing 3,990 was 60MPH? and that is about what I got, within the width of the needle error.
                If you believe those construction zone speedo indicators then my speedo was always 1 mph optimistic when the tires were new and about 2-3 when they were about to be replaced - 75 MPH indicated was 74 on the PennDOT indicator. Er I mean 50 MPH indicated was 49 on the PennDOT indicator. 75 MPH is of course not allowed in a construciton zone.
                Marty in NW PA
                This IS my happy face.
                • #23
                  Add 500RPM for a Special. 80 MPH would be 5500RPM
                  Pat Kelly
                  <p-lkelly@sbcglobal.net>
                  1978 XS1100E (The Force)
                  1980 XS1100LG (The Dark Side)
                  1999 Suburban (The Ship)
                  1994 Dodge Spirit (Son #1)
                  1968 F100 (Valentine)
                  • #24
                    I remember noticing on our ride down I-5 to Los BaƱos last summer that cruising at 85 on my Special the tach was right around 6100 rpm which neatly coincides with the engine's torque peak. A twist of the wrist brought a positively vicious roar from the air box and a quick yank to over the ton.
                    Shiny side up,
                    650 Mike
                    • #25
                      Maximan,
                      I checked my XJ today, and it was right at 4k at 60mph, like you remembered... and just a sliver over 4500... maybe 4600-4700 at 70... but again... going by my old gauges.
